  2. Dismiss Notice
  1. KrisKrk
    KrisKrk A6 C6 4F 2010 LeMans Avant
    2,702
    2,474
    Has anyone experienced leak from rear end/boot area in theirs Avant’s?
    Got this today
    This morning had puddle in that area
    This spot happen within 3 hours
    Could it be leak from fuel tank?
    Certainly doesn’t smell like diesel
  2. Avatar
    snack-media
    Advertisement
  3. Rob1967
    Rob1967 Member
    Don't know if you had any rain but my avant used to leak in through rear lights on tailgate. And also rear washer piping prone to leaking and wetting boot
  4. KrisKrk
    2,702
    2,474
    It rained Thursday and it would need to accumulate somewhere to let out now.
    This liquid is greasy and slippy.
    It is also bit browny, as in the second picture.
    Will inspect it closer
  5. niedzial1983
    niedzial1983 Active Member
    337
    136
    43
    Check if there is no water under spare wheel as well
    Sent from my SM-G950F using Tapatalk
    KrisKrk likes this.
  6. KrisKrk
    2,702
    2,474
    This is the puddle found this morning
    Good 12”+ in diameter and still there since 11am when first seen.
    Should be dry by now but as it’s greasy, it doesn’t evaporate.
    Found some moisture in the spare wheel well and looking at it mould from underneath the boot, it did leaked from one of the well drain plugs.
    I washed the car last week Saturday, before aitp. Could it leaked just now, if there was no rain till Thursday only?
    Any ideas where water could get in there from?
  7. Seanchadwick2k3
    Seanchadwick2k3 Audi A6 C6 2.0tdi 2011 Sline Special Edition
    497
    268
    I have a similar stain under the rear of mine from the previous owner leaving a bottle of oil with the spare and the lid not being on properly. Maybe leave something underneath tonight to catch it in so you've got a better idea of what it is?
    KrisKrk likes this.
  8. KrisKrk
    2,702
    2,474
    Cheers Sean,
    Barely could dig the stuff I keep in there out to check for water ingress. Got a bad back today but had to check it provisionally.
    Thought it will be fuel tank but, as mentioned above earlier, it isn’t diesel nor any oil. I do have a 1litre oil bottle for top up from last service but not much in there left and lid is solid on.
    Have fuel additive with less than 1/5 remaining in it but again, lid is on properly.
    Both bottles been squeezed to check for leaks and they are good.
    Will check tomorrow morning
  9. niedzial1983
    337
    136
    43
    Have you got a sunroof ? Also check if the area around the amp is dry , bottom of the boot lid etc. Common issue on avant is washer fluid leak going to rear wiper
    KrisKrk likes this.
  10. KrisKrk
    2,702
    2,474
    No sunroof on mine.
    In the amp compartment have a lot of junk but will dig it all out to check in there also. Thank you for the tip.
    Washer fluid would dry within the time I went for shopping. Nothing is sloshing around in the tailgate. Boot floor carpet and other boot panels are dry.
    Will investigate further.
    Cheers fellas for input
  11. Roadrunner146
    Roadrunner146 Active Member
    366
    82
    Is it brake fluid.
    KrisKrk likes this.
  12. Avatar
    snack-media
    Advertisement
  13. KrisKrk
    2,702
    2,474
    Hmmm
    There was no colour to the liquid on the floor and in the wheel well. Definitely no smell was there either.
    Brakes feel solid.
    Today feeling better (atm) so will check it again when back from work.
  14. KrisKrk
    2,702
    2,474
    Yesterday had time to check it out.
    Liquid like cooking oil
    Turned out to be an engine oil I had a 1 litre bottle of with some remaining in it.
    When I checked it last time, I’ve squeezed the bottle holding the cap so it looked like it was sealed properly. Yesterday I grabbed on hand and it leaked out.
    All gone out from one of the drain plugs in the wheel well.
    Did facepalm do hard, forehead still hurts. Lol
    Thank you all for input.
    Glad it wasn’t anything serious
