Le Mans offset
Martin Carter
Hi Guys,
New to the forum so still learning how to drive it! I have a wheel offset question I have a A5 3.0 Tdi Coupe with 19" Le Mans and I want to change to 20" Le Mans I've no idea without taking off a wheel and looking what the ET number is on mine and no idea what ET number I need on a 20" Le Mans I see many that have been on A6, RS4 etc but what offset do I need.... Thanks for any help you can give me :grinning:
JG51 AUD
A5/S5 wheel offset is 33 for a 19x9, and 32 for 19x8.5, if your wanting to keep the same offset on a 20 inch wheel, suggest you go for 33 or 32. You can go lower than these sizes, but I wouldn't go higher, or you will need spacers to bring the wheels out from the hub/brakes.
JG
JG51 AUD
Hi, thanks for the reply the wheels I'm looking at are ET29, so am I right in thinking they are ok?
Yes, they should be fine. :thumbs up:Just make sure the centre bore is the same size, and not smaller than 66.6.
JG
JG51 AUD
JG51 AUD
JG51 AUD
255 x 30 x 20, or you may bet away with 255 x 35 x20, but this will mess with your speedo at slight bit.
Put your sizes into, willtheyfit.com to see speedo differences.
JG
