Launch control issues
syed123 Aug 2, 2018
  1. syed123
    syed123 Active Member
    244
    76
    Hi all,
    To all the 272 and even s4 owners - has your car ever had issues with launching via the zf 8 speed?
    The last few times I've launched from 3500rpm the car hasn't had that same sling shot rapid acceleration feel it normally gives.
    It's as if It doesn't want to? Possibly straining my gearbox perhaps..
    I don't know how many launches I've done but I've done quite a few in the past.
    Just wondering why it's not feeling how it's supposed to.
    Going to lay off the launches for now but it's annoying as I do want those sling shot launches back!
    Any advice/opinions appreciated
  2. Avatar
    Google AdSense Advertisement
  3. terminator x
    terminator x Well-Known Member Team Nardo Team V6 Audi RS4
    3,634
    4,037
    LC limit is 200 apparently, LC stops after that but can be reset with laptop etc.
    TX.
  4. syed123
    244
    76
    Is this actually true?
    I've had the car for 2 years now so 50 50 that I've done that many launches..
    How exactly do I reset it using laptop?
    I recall the post earlier about rs3s being limited to 200 but does that also apply to the 8 speed zf?
  5. terminator x
    3,634
    4,037
    Imho why would it just be the RS3 with a LC limit? Proven to exist in the RS3 section as there is a LC counter. Need vcds etc to reset it afaik. Tbf the launch in the 4 is probably harder on the car as it holds it on the brake vs a dsg car where clutch etc not engaged until launch.
    TX.
  6. syed123
    244
    76
    Fair enough, makes sense I guess.
    I agree, holding the revs just using brake and also 700nm of torque going through the gearbox during a launch. Even 600 was enough but I only ever launched it once it was tuned.
    Any members on here know how to reset this via vcds etc?
  7. terminator x
    3,634
    4,037
    @DJAlix would know for sure.
    TX.
  8. syed123
    244
    76
    Thanks! Will pm him now
  9. A12RNX
    A12RNX Active Member TeamMisano Team V6 Audi S4 saloon Audi A6
    181
    148
    43
    I think the counter limit is BS otherwise they would have to state the limit somewhere in the manual. Also found this on the gearbox:
    Eight-speed tiptronic
    The eight-speed tiptronic is a classic torque-converter automatic transmission whose great strength lies in its high level of shifting and drive off comfort. Gear shifts are gentle, spontaneous, fast and highly flexible. Audi uses it in many models with a longitudinally mounted engine. Thanks to its eight speeds, jumps in rpm are small between gears, and the engine always runs near its ideal operating point. An rpm-adaptive torsion damper balances out undesired engine vibrations and enables efficient driving at extra-low engine speeds.
    Also playing a large role in the efficiency ensemble is the torque converter lockup clutch with integrated damper. Under normal driving conditions, the lockup torque converter connects the transmission directly to the engine. It works with limited slip in certain situations, which – in interplay with the integrated damper – permits very low engine speeds without vibrations occurring. If the car is stationary, an internal clutch decouples the transmission from the engine, even if the “D” stage is still selected – this avoids losses due to oil circulation in the converter. As soon as the driver releases the brake, the clutch closes, and the damping effect of the torque converter ensures a smooth drive-off.
    The dynamic shift program (DSP), which controls the eight-speed tiptronic, is housed in a small steel box within the gear-shift unit. It utilizes a fast processor. In the “D” mode, DSP autonomously sets the optimal shift point. To enable an efficient mode of driving, it gives preference to large gears and low engine speeds. In a second shift gate, the tiptronic allows manual intervention in the automatic transmission’s operation. This allows downshifting, e.g. on winding descents to boost engine braking or for driving in an exceptionally sporty style. In sport mode, the automatic transmission boosts driving dynamics by setting later shift points. The selector lever communicates fully electronically, without any mechanical connection with the transmission (shift-by-wire).
  10. terminator x
    3,634
    4,037
    @A12RNX the RS3 definitely has a LC counter, screen shots of the counter have been produced in that section.
    TX.
  11. A12RNX
    181
    148
    43
    @terminator x i believe there is a counter I have seen people post pics of the VCDS screen grab. I can’t believe that there is a limit to something without it being told or said anywhere in the manual. Surely that is against consumer rights.
  12. Avatar
  13. terminator x
    3,634
    4,037
    There is a chap who is LC happy and his LC stopped at 200 he has screenshots.
    TX.
  14. Riko0073
    Riko0073 Well-Known Member Team Daytona V6T Audi S4 Audi Avant Owner Group
    658
    559
    93
    Other than on a track day/drag strip do people really use the launch control in daily driving?
    I’d feel a bit of a knob sitting at the traffic lights with the engine revving until the lights go green personally!
  15. Paul Golding
    Paul Golding Active Member Team Brilliant Black TFSI Owners Group saloon Audi A4 S-line owners group S tronic
    314
    179
    43
  16. terminator x
    3,634
    4,037
    Paul the 8V isn't "old" and it absolutely is limited to 200 launches. The OP in this thread also maintains his car won't now launch after being 50/50 on maybe being that high too.
    TX.
  17. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 Audi Avant Owner Group quattro
    2,939
    1,422
    I'd be quite surprised if our cars were limited from a gearbox stress perspective, since we don't have the same sudden clutch engagement as the s-tronic models and therefore shouldn't stress things quite as badly. Obviously it'll be a bit more than just mashing the loud pedal though. I don't know for sure, just a thought is all?
  18. A12RNX
    181
    148
    43
    @syed123 with the LC not working did it stop working after you have already done some that day? People have said if the gearbox gets very hot it stops LC from working that might be the case to stop people doing them back to back.
    Also with the amount of torque you have going through the torque converter that will generate a lot of heat. Just a thought.
    @Riko0073 i have used it a couple of times when racing a C63, m3s and other cars that are faster but the launch on these cars is incredible and gives you the edge in most cases. Plus while the car still has warranty I would rather use the feature now because if something breaks I can get it replaced, as long as I don’t abuse the function.
    terminator x likes this.
  19. syed123
    244
    76
    The last time the car did a proper launch was about 2 months ago.
    I remember trying it a month back n that's when I first felt something was wrong as it didn't take it off the way it used to, it was quite average actually, even flooring it felt quicker.
    It's weird because other than the launch control the car is driving very nicely.
    I did also flash the tcu but I remember the launches still working fine until last month.
    A12RNX likes this.
  20. syed123
    244
    76
    The launches weren't consecutive either. Didn't do them instantly back to back
  21. cuke2u
    cuke2u Well-Known Member TFSI Owners Group saloon Audi A4 S-line owners group
    10,032
    3,762
    There are so many variables with the gearboxes being quoted here though and this might make a heap of a difference to launch limiters. The s3 has a dsg, where as the s4 has an automatic box with a torque convertor, so one may not apply to another. Then there are the variables within the dsg boxes themselves, whether they have dry or wet clutches...
    Daggerit likes this.
  22. A12RNX
    181
    148
    43
    What was the TCU flash for? Was it an Audi thing or 3rd party?
  23. syed123
    244
    76
    Tmc motorsport tcu remap - basically flashes the tcu unit to make faster gearshifts/driveability release extra torque.
    I suspected this to be the reason at first and even rang the company who said they had never heard my issue before.
    I don't think it is that though as apart from the launch control not working the gearchanges now and overall driveability is excellent
    Plus the first few launches I did wen I first flashed the tcu were fine also
  24. A12RNX
    181
    148
    43
    Presuming you don’t have warranty left on your car? Otherwise might be worth flashing back to standard and getting Audi to have a look.
  25. syed123
    244
    76
    I'll probably take off the tuning box also then, my only concern is Audi will just try to put the blame on me saying that u shouldn't be launching the car that much as it causes a strain on the gearbox etc..
    A12RNX likes this.
  26. syed123
    244
    76
    And still have warranty
    A12RNX likes this.
  27. Dippy
    Dippy Well-Known Member Team Monsoon Audi S5 Black Edition
    1,517
    973
    I only briefly read the above comments so sorry if I missed something.
    LC only applies to s-tronic because the clutch release needs to be controlled by the TCU. Clearly it causes clutchpack wear which is why Audi included the counter.
    On the other hand tip-tronic has a torque converter gearbox such as the ZF. This is designed to allow the engine to rev whilst the gears are engaged and the brake applied (which is what happens at every stop junction and traffic light). So LC is not needed (or you could say that it is "inherent"). Due to the action of the stator there can be torque multiplication and this is highest near the stall point. However since the transmission fluid is viscous, a lot of heat can be generated by maintaining this for a period of time, so it is best to only rev the engine to near the stall point right before you want to launch.
    I'm not sure why the OP's recent launches did not feel so good but I'd suggest that heat may have been an issue. With the recent hot weather the engine and gearbox will be hotter than normal and perhaps the launches are raising the temperature to such a level that the ECU is intervening and reducing engine torque.
    syed123 and A12RNX like this.
  28. syed123
    244
    76
    Agree with a lot you've said - the launches simply don't give that elastic band feeling slingshot feel I normally would get, so I'm assuming it must be the recent heat aswell
    I'm going to probably give it a rest with the launches for now I think.
    But I hope I get those launches back soon!
  29. SRB93
    SRB93 S5 B9 Coupe - Glacier White Team Glacier Team V6 Audi S5 Coupe
    412
    142
    43
    I'd suggest letting someone else doing it whilst you're in the passenger seat (Permitting you'll allow anyone to do it) and you may feel the difference.
  30. syed123
    244
    76
    That wouldn't work lol,
    Believe me there's a night and day difference.
    Normal flat out acceleration feels stronger when it's meant to be the other way round.
  31. Flowrider99
    Flowrider99 Active Member Team Mythos Supercharged TFSI Owners Group Team V6 Sportback Audi S5 Black Edition quattro S tronic
    293
    130
    43
    I've never seen the need to use launch control as my S5 pulls away fast enough for me as it is. Does LC make that much difference?
  32. syed123
    244
    76
    For my car it does.. When my car was stock it did 0 60 5 seconds dead with launch and 5.2 without
    With the way it is now it does 0 60 in 4.3 with LC and around 4.8/4.9 flat out
  33. Avatar
  34. cptjay
    cptjay Active Member
    124
    55
    Found a substantial difference in the S4...
  35. terminator x
    3,634
    4,037
    LC snaps your head back, very different imho.
    TX.
  36. Paul Golding
    314
    179
    43
    Much less so in a non-quattro, as I found out at the weekend. Turning off TC makes it all a bit on the noisy side:tearsofjoy:. But at least I gave it a go.
  37. bennymac
    bennymac Member
    33
    interesting thread I have only used LC to show off and wow …. nearly everyone feels sick after it and I really struggle to hold on ha ha.
    absolutely huge difference on mine to a flat out pull from stationary
    syed123 likes this.
  38. syed123
    244
    76
    S4 or 272?
    I miss mine! Still not back to the way it should be.
    Will get a vcds check done very soon I think as not much left I can do..
