Key programming
Arkious
I have an 8P RS3 and I have gotten a blank 8V RS3 key which I would like to use instead. Now the keyblade is an easy switch over obviously but I no idea how/where to get it programmed.
The frequency of both the 8P and 8V keys are the same, and they have the same 3 button layout so presume it will ‘teach’ fine.
I can’t simply swap the guts out as the internal design is different (and better) in the 8V key.
Hope someone can point me in the right direction, cheers :)
LockSafe
I am an Auto Locksmith.
The 8V key will not program to the 8P car.
I can supply you internals for the 8V remote that will code in fine, as can most decent Auto Locksmiths. The transponder will swap over as will the blade with very slight modding.
I would suggest that you speak to a local Auto Locksmith who can sort you out properly.
chasen
What device do you recommend to do Auid Key Programming?
chasen
Depends on your budget, skill level, access to keys etc.
I recommend a good Auto Locksmith. Audi keys are a bit tricky.
Audi and Benz,which is more tricky?
And can you tell me what device you are using to program keys?
