Do you plan on changing the turbo? If not then the standard injectors are fine.Do you know if the standard BUL injectors are ok for 300-325 bhp or will you need the high flow variety from the s3?
Sent from my ONEPLUS A6013 using Tapatalk
You'll probably need an uprated PRV. The RS4 one should be plenty. I have one I could sell you if interested. To answer your original question, you would probably benefit from S3 injectors especially if you plan on flowing more fuel.I’ve got a k03 hybrid fitted, just wondering if Rob is planning to use the standard injectors or not?
spec below, they are £600 from venom turbos. I need fuel pump internals for sure as with the current map it’s cutting boost at 5000 rpm, can’t maintain 120bar
Over Sized K04 Aluminium Billet Hi-flow Compressor Wheel With Extended Tip Height
• Machined Compressor Housing, Profiled and Polished to Minimum Tolerances for Optimum Flow of The Charged Air
• Uprated 360° thrust kit
• Step Gapped Performance Shaft Piston Ring
How much you want for the s3 injectors?and some s3 injectors freshly serviced
How much would a set up like that be?Are you looking at the 420/430 hp spec ko4’s?
The ATP 450 hp kit keeps talking to me to put it on a credit card.....
If that gets you around 450hp then that seems like its priced well, im still concerned about the price of a clutch for stage 2+ let alone one thats going to handle what I expect to be atleast 450ft lbs from that turbo lolIts $3000 stateside so you have to be creative to avoid the 20% surcharge to the UK and it still needs the same ancillaries as a Ko4 hybrid.
I got an email the other day about a discount on ko4 kits, my credit card was getting itchy in my wallet, lol
Don't mean to hijack but I have a prv I could sell you unless Rob already had one he wants to sell you.Do you have a part number for the rs4 prv Rob? I could do with one to get the most out of the mid range.
Yeah that would be great thank youDon't mean to hijack but I have a prv I could sell you unless Rob already had one he wants to sell you.
What've you got, Rob?
I was quite temped to go with this but was put of by some negative reviews on it.
https://fr-rtuning-shop.co.uk/audi/...bo-kit-400bhp-for-the-audi-a4-b7-2-0tfsi.html
Uprated fuelling system and should be an animal then.I didn’t see Any bad reviews when I researched, just people laughing that there was serious fuel cut in the dyno and it was obviously a conservative tune by ATP.
the 450hp version with external wastegate looks nice but the price tag goes up a fair bit more.
Not sure if this will be any use to you Rob but just been browsing on Copart and found this
https://www.copart.co.uk/lot/29475020
No details or specifics and no guarantee its a BUL but if it comes cheap and you can find a way of bidding it might come cheap.
