  2. Dismiss Notice
Just done the throttle response mod
Mikeyd1 May 16, 2020
  1. Mikeyd1
    Mikeyd1 Registered User
    66
    23
    As title says I just done the throttle response mod through obdeleven.just what the 1.5 petrol needed. I can definitely feel it.
    dp_motley likes this.
  2. Avatar
    snack-media
    Advertisement
  3. The_Ironist
    The_Ironist Registered User
    440
    249
    43
    Is this the same as gradual to direct mod on Carista?
  4. Mikeyd1
    66
    23
    Yep
  5. dp_motley
    dp_motley 2012 A3 1.6 TDI S line 2019 A3 35TFSI S line
    1,255
    489
    How did you do it? I own both 1.5 TFSI (35TFSI) and the obdeleven. Could you point out where to look please?
  6. Mikeyd1
    66
    23
    Here’s a screen shot where I got it from
  7. 8v1.8tfsi
    8v1.8tfsi Registered User
    89
    What is the throttle response mod and what does it do ? Does it make the accelerator pedal more loose when you press it ?
  8. The_Ironist
    440
    249
    43
    I need to change mine back to default to see if I notice the difference, had it on the direct so long.
  9. Mikeyd1
    66
    23
    Let me know your findings as u had it so long u are in a great position to notice the differences or if it’s just placebo
  10. gringosteve
    gringosteve Registered User
    189
    43
    Run my S3 with this on for a year or so
    1) it isn’t placebo, have swapped it back and forth
    2) on the S Tronic box it can make smoother driving at low speeds problematic in anything other comfort mode
    3) it uses a bit more fuel
    4) it’s much nicer to drive at pace
    Sent from my iPhone using Tapatalk Pro
  11. Mikeyd1
    66
    23
    That’s good to know, the 1.5 can be slightly jerky at lower speeds so I’ll see how I get on with it,but yesterday it felt quick but I was driving a bit spirited shall we say
    gringosteve likes this.
  12. Avatar
    snack-media
    Advertisement
  13. steverobertsbbc
    steverobertsbbc Registered User
    474
    216
    43
    I presume that all this is doing is changing the relationship between pedal position and throttle opening so that your foot has to push down less for a given throttle opening? I used to do this when I was a kid, tightening the slack out of the accelerator cable so that the lightest touch would make the engine race! Felt much faster until you overcame the muscle memory and adapted to the new limits. :p
  14. dp_motley
    1,255
    489
    I done it earlier today too :) I could feel some difference during a short city driving. It wasn't jerky at lower speeds despite my 1.5 TFSI engine with the s-tronic. I tried both on Auto and Comfort. I'll see how it's gonna work tomorrow on a longer journey to work and back.
  15. Mikeyd1
    66
    23
    After taking my car out today I can definitely feel it. Keep us updated
    The_Ironist likes this.
  16. gringosteve
    189
    43
    Not really
    The standard pedal map is non linear. It takes into account how long your foot is in a Position for and how fast you step on the gas. It irons out jerks but feels nothing like a traditional cable driven throttle. My one gripe with the car.
    The other setting is linear in nature and closer to a normal cable throttle as opposed to drive by wire. It doesn’t iron out small changes. Much nicer
  17. dp_motley
    1,255
    489
    I did it and I wrote I felt difference. Well, that could be placebo. I checked out in EBDeleven and found out that the change of the setting was not saved. I tried again without any luck. I choose "direct" from the drop-down menu, press and hold the confirmation button and it looks like it is saved, but when I leave this screen and then come back, the setting is changed to "incremental" again. So I guess I didn't even try the linear/direct mode. Did anyone experience the same issue?
  18. quattrorally
    quattrorally Registered User
    207
    80
    I can see this is possible with carista. anyone tried it with carista?
  19. The_Ironist
    440
    249
    43
    Yep did mine with Carista. Have been using it for ages now with the mod, haven’t had a chance to change back to see if there is a difference...also it would cost me on the app to do so.
  20. Morris39
    Morris39 Registered User
    Agree. Doubly subjective. How sensitive is your foot coordination and how smooth can you do it. And if you are inclined think that the effect is more than the obvious one, how open are you to do some more thinking.
    This device is now fitted to most motorbike throttles. Very popular.
  21. makelja
    makelja Registered User
    307
    244
    43
    I checked mine with VCDS and it was already set as direct.
  22. dp_motley
    1,255
    489
    But you changed and saved it with VCDS, did you? I guess that OBDeleven can't save this change for some reason.
  23. makelja
    307
    244
    43
    I did not change anything as it was already in "Direct".
