- Joined
- Feb 4, 2016
- Messages
- 333
- Reaction score
- 51
Hi guys, just signed up to here and I've been viewing these forms ever since I purchase an Audi A4 59plate S-Line SE White last year
When we received the car we noticed it hadn't had the timing belt done so it went back in and the work was carried out for free. Ever since then the car has had a slight intermittent judder in first, it's easily noticed when sitting at a busy roundabout and you have to press the gas
We have just had the car in at the Audi garage and the tech guy went out to test the car and came back within 10minutes. The report which I have in an Email states that when the clutch is let off....ill let you read it as I've posted it below bottom of this post
Now the things is, we purchased the car 30th July 2015 and I made the call to Audi to report the problem around the 20 January. I've just been reading up on the OFT guidelines and the Consumer Rights Act. Apparently if anyone who has purchased a used car before October 2015 (as they have introduced new guidlines) then as long as the fault has happened between 30 days and before 6 months then you can have the car fixed by the dealer. It does state however the dealer is not liable for fair wear and tear, this is where I have to make a case, although the car is a 59plate its only done 38,000 miles. The judder should not be happening and this isn't normal for a car, which I think is just a bad, lame excuse from the garage!
The Audi garage did state that for them to drop the car and examine was going to cost £400 :-O
so what do you guys think I should do?
Tech Report:
The technician went out with the car for a roadtest, when pulling away from a junction in 1st gear, if there was no acceleration while releasing the clutch then slight judder was felt. Once accelerator pressed then car drives away with no judder.
Technician does not think there is any fault with clutch at this time.
For us to check wear on clutch etc, we would need to remove gearbox to inspect this. If we then found manufacturer fault with flywheel, we could then go on to your extended warranty company for authority. If only wear on clutch found then cost to replace this would be down to yourself.
The cost to remove gearbox for inspection of clutch would be down to yourselfs to authorise.
Tech Report:
