Thanks for sharing the results Oli! Was your car stock? Funny that map2 gave more power than more aggressive map6..
I went for my dyno run today and I had a fantastic day and my ears are slowly recovering
The car made 367hp at the fly, 328 wheel hp and 368 Ib/ft. For £400 and some help from George i'm amazed!
Run 1 - Map 6 (Good ING advance, IAT weren't too high)
Run 2 - Map 6 (ING advance dropped to below 5 as IAT was climbing but still made best power?)
Run 3 - Map 4 (should be stock but it works out at 325hp fly?)
Run 4 - Map 6 (IAT was very high, still a good result for a heat soaked car)
So second run is map 6 or 2?
Which gear was use?
Nice!
How was it again, is your car completly stock besides the Jb4, or does it have slight hardware mods like intake, inlet elbow, etc?
The 325 on map4 is a bit odd I agree (unless you have full bolt on mods). Didn't think the Jb added any boost there. Wonder what George says...
There's no map 2 runs, i wonder why u didnt we cud have compare with map 6 runs. Anyway those are impressive runs, u need some more bolt-on mods to support iats.
Sent from my HTC 10
Happy to have the info to share
I'd read the post again
I've pulled the snow gate out the air box and the exhaust flaps are open, other than that nothing else
I think so, seems like the best bang for buck mod anywayThat's really impressive I think for completely stock esentially.
Can you share your map 6 settings?
Keen to compare to mine, which are below.
I'm doing a dyno day soon and will post my numbers.
Run that and post your logs for me please.
60 as it was out of the box for me.Cheers !
What fuel open loop are you running ?
Let me know what you think of these settings, made mine a torque monster compared to map 2
My settings
I got r600 intake. Fuel vpover nitro 100
FOL 60 but I got error code when scanned 3AD2 which is fuel rail pressure low. That's very weird because I have not seen check engine light
Thanks for advice.That's not so unusual.
Got that code a few times with Jb1.
After following George's recommendation, avoiding full / high trottle with less than 25% gas left in tank, I have never gotten it again.
If that's not enough, lowering FOL to 50, or 40 in some cases, usually helps.
That's interesting as I found map 2 a bit too aggressive as a daily drive, hence George helped me with my current map 6 set up. I'm getting high 3 second 0-60 times with the following mods on map 6.
BMS Intake
BMS turbo inlet elbow
BMS turbo muffler delete
GFB DV+
Agree that the JB4 is great bang for buck !
I'll run your settings this week and report back
Audi S3 MY16 Daytona Grey
Cheers, I wish I'd of thought of it as wellImpressive results.. would have loved to if seen a map 2 run for comparison
Today refilled gas and did few WOTs. No error codes!That's not so unusual.
367hp with no major mods
You could try my settings and post the logs?with my mods do u have any tips on things i could change? george sent me this but i havent got round to doing it yet....
It's the key to making the best power unfortunately, I just use my phone with an otg adapter.i will give them a go tonight, im not to good with a laptop and logging tho lol
You can use either the value you want over stock ie +5psi or the value you'd like the car to reach ie 20psiis wot george is telling me to change the same colum that u have changed, getting confused with your 1500 - 15.0 and georges being 1500 - 2 or am i missing something ?
I did a double take on that 0-60mph and then realized...Love my JB4
Love my JB4
jb4 for sale if anyones intrested
