Jay's 2.0CR 395hp 650nm
bobby singh Apr 15, 2017
  1. bobby singh
    bobby singh BSR VCDS Map User TDi Audi A4 quattro
    758
    446
    CBBB
    2.0 CR
    BSR CP3 kit
    BSR Ported head with custom springs
    Hybrid VKLR
    Injectors - yes it has some
    Plus other custom parts
    Bobby
    AdamC95, Horia, KrisKrk and 2 others like this.
  2. Avatar
    Google AdSense Advertisement
  3. Gazwould
    Gazwould Well-Known Member
    6,482
    2,631
    Crikey , I hope it's a quattro ?
    bobby singh likes this.
  4. gray99y
    gray99y Active Member Team Monsoon TDi Audi A4 Black Edition quattro S-line owners group
    425
    123
    43
    That's impressive, my 2.0tdi runs at 208bhp
    Sent from my SGP621 using Tapatalk
  5. 344bigal
    344bigal Member
    79
    47
    Now that's impressive, I'd love to see some more about this car.
    Sent from my SM-G920F using Tapatalk
  6. bobby singh
    758
    446
    Thanks guys - alot of custom and unique parts.
    Glad all the parts work so well :)
  7. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi Audi A4 Audi Avant Owner Group quattro
    6,726
    3,203
    Impressive but why is it a world record? . Surely adding some nitrous onto a lesser build would net more power. I believe that the car is a FWD as the dyno is in shoot out mode 4F which is for 4 cylinder Forced induction cars. Shoot 44 would be for a 4WD car. So I bet that's interesting to try and drive quickly in the wet :) . The custom springs to try and keep the inlet valves shut due to the amount of boost pressure ?
  8. Darren92
    Darren92 Well-Known Member
    2,377
    615
    My 2.0 TDI (Passat) standard is 240ps/500nm although it is helped along by 2 turbos :)
    Your work is impressive however, I don't think I could justify the cost though!
    QuattroCalum and bobby singh like this.
  9. bobby singh
    758
    446
    Karl anyone can add nos but thats cheating lol
    There is no one that I'm aware of thats running over 255hp in the UK. In Europe there are many claiming 280hp or even 300hp but yet this car at 255hp was pulling same 1/4 mile times and trap speed as higher claiming cars - pretty conclusive for me.
    Yes its FWD - has wheel hop at 3k and wheelspin in the dry at 4.5k (in 3rd).
    Emp is 1:1 with boost so its flows really well with under 900deg egts.
    344bigal likes this.
  10. desertstorm
    6,726
    3,203
    I know what you are saying about dyno figures and real world performance, It's so easy to massage figures and even if there is no obvious attempt to get higher readings the absolute numbers don't always reflect the driveability or performance in the real world.What kind of 1/4 mile times is the car running ?.
  11. DeanoC
    DeanoC Well-Known Member VCDS Map User
    841
    836
    93
    Bloody impressive work but devils advocate here on the point of it if i may? That can't be fun to drive keeping it in a 1500rpm powerband from 3500k rpm to 5000 rpm? From a headline figures perspective you have more torque than my RS4! but i keep 90-100% of my headline torque from 3k to 8.5k whereas you go down to 60% of your headline figure within 1500rpm then have to change gear - that must be hard work/boring as hell?
  12. Avatar
  13. bobby singh
    758
    446
    1/4 previously was 13.6 @ 102mph iirc
    Hoping to get into 12's with good trap speed.
    I think side by side it could take mine lol
    But I have more plans for mine.
    Deano - I agree its become more laggy but we've gain some rev's top end. Over 300hp between 3.5k to 5.2k
    You soon forget about the lag :)
  14. Gazwould
    6,482
    2,631
    More plans.... :congratulatory:
  15. Horia
    Horia New Member
    14
    What plans for your car Bobby? ❤️
    S300:superman:...
  16. xJay1337
    xJay1337 New Member
    22
    22
    TDI ratios are much longer than a petrol not forgetting.
    Compared to 2260 it's so much faster, it is a bit laggy compared to the 2260 true - but perfectly usable to drive daily if needed and it has so much more performance at the top end.
    If you change at 5000 rpm revs revs drop to around 3500 so you are always in the powerband when on it and always making over 300 BHP. :)
    Think of it like Vtec for diesels lol
    Excellent work Bobby.
  17. 2.0TDI_Jo
    2.0TDI_Jo New Member
    22
    10
    WTF!
  18. adamss24
    adamss24 Well-Known Member
    4,584
    411
    To the nigh Sayers I have been in a 2.0 tdi previously pushing over 300 Bhp also FWD- it was scary and nearly killed me Twice ! It had all the goodies: Bilstein PPs9 susp suspension, rs4 braces, sticky tyres on 19" wheels and a lot of custom parts as well. It was a pd engine running a gtb2260vklr hybrid. Good work as usually Bobby ! Well done mate !
  19. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,903
    686
    300 bhp in a front wheel drive that's just asking for trouble
  20. bobby singh
    758
    446
    Cheers Chris - how are you?
    New place all set up?
    It's def a handful but fun at the sametime - like Jay said you better think twice before allowing the rev's to hit 3k :)
  21. adamss24
    4,584
    411
    Working on it mate, time goes a bit slow over here !
  22. bobby singh
    758
    446
    Update:
    340 becomes 395hp
    625 becomes 650nm
    Old Vs New
    So close to 400 :)
    Maybe on a cooler day
    Enjoy
    344bigal, Horia and KrisKrk like this.
  23. bobby singh
    758
    446
    @desertstorm
    Karl could you edit the title mate with:
    "Jay's 2.0CR 395hp 650nm"
  24. desertstorm
    6,726
    3,203
    Very impressive Bobby, well done. That's crazy power from a 2.0 TDI without any chemical assistance.
  25. bobby singh
    758
    446
    Thanks Karl
    Indeed - it was a bit worrying logging this..
    Pulls very hard once it grips
  26. QuattroCalum
    1,903
    686
    Should get a tyre sponsor for it
    Sent from my ANE-LX1 using Tapatalk
    Gazwould likes this.
