  2. Dismiss Notice
Jack point & axle stand position?
JohnStan725 Nov 11, 2015
  1. JohnStan725
    JohnStan725 Registered User
    147
    9
    Hi guys
    I'm doing a full suspension change at the weekend just wanted some advise on where the best place/recommended place for jacking the car up is? Also once it's jacked where the proper position for the axle stands are?
    I have been told the to Jack it up from the lip and use the axle stands on the metal frame going underneath wanted to double check with someone who knows abit more about this.
  2. Avatar
    snack-media
    Advertisement
  3. Tom93
    Tom93 Registered User
    436
    79
    Yep thats how i do it. Just be careful if your changing wishbones that you dont put the stand in the way of the rear wishbone bolt.
  4. JohnStan725
    147
    9
    Thankyou Tom! Ahh okay is it something visible whilst placing the Jack underneath?
  5. Stuart B
    Stuart B Registered User
    3,448
    743
    I have damaged both my cars in 2 weeks by jacking in the wrong place :(
  6. JohnStan725
    147
    9
    **** Stuart, that's not good where was you jacking it up from to damage the car? Just so I avoid doing it? Also Tom can you confirm I place the axle stands in the subframe underneath?
  7. IPG
    IPG Registered User
    1,841
    778
    pics of where to/where NOT to would be ace!!!
    mine will be living on stands for the next month i think
    JohnStan725 likes this.
  8. JohnStan725
    147
    9
    Ian I agree, I will upload a picture or two tonight on where I believe you are ment to Jack it up and place the stands. Did it last weekend no issues just wanted to make sure I'm doing it properly.
    IPG likes this.
  9. Stuart B
    3,448
    743
    Mine is from a trolley jack on a punto slightly closer to the wheel on the sill and the S3 slipped off the jack point when I turned the steering when the car was just jacked up 70%. its so annoying, usually put some wood along there, I prefer the tyre place with the inflatable jacks which spreads the weight better.
  10. Prawn
    12,096
    4,331
    I use a low profile jack and jack off the chassis rails further inboard. Wouldn't ever jack off the sills personally.
    If using axle stands, I jack off the subframe and put the axle stands on the chassis rails to allow uninterrupted access to the Subframe.
    scotty_24 likes this.
  11. scotty_24
    scotty_24 Registered User
    1,160
    321
    I do this prawn too, or off the big bolt at the rear of the subframe
    My sills have collapsed and folded in over due to jacking up on them
    They are made of cheese
    Just gotta watch you don't scrape the under seal off
  12. Avatar
    snack-media
    Advertisement
  13. IPG
    IPG Registered User
    1,841
    778
    Prawn what do you mean by the chassis rails that are in board? I'm doing axle stands both front and back ad would like to be able to drop sb frame :)
  14. Prawn
    12,096
    4,331
    take a look under the car. about 300mm in in line with the front edge of the doors, you'll find a box channel roughly 50x50mm.
    IPG likes this.
  15. IPG
    IPG Registered User
    1,841
    778
    I'm going to roll with this area for the back?
  16. IPG
    IPG Registered User
    1,841
    778
    In the end I went with these spots
    Front
    Back
