Hi Guys,
I've just purchased and 2016 Audi A4 B9 1.4 tfsi and I am having issues with a Reverse Camera Retrofit.
The camera was purchased from Carlise Audi's eBay store and came with instructions and OEM harness.
The issue I'm having is with the adaption and coding of the camera. When trying to enable VPS in 5F I keep getting request out of range using VCDS. It also looks as though the camera module isn't coded, but when trying to code I get: Coding Rejected. Error 22: Conditions not correct or request sequence error.
It appears as though I have also messed up the coding for 5f and get a coding error on that too (see full scan).
I've attached a full scan below and was wondering if anyone has come across similar issues and would be able to help. Thanks in advance
Code:
Saturday,19,December,2020,15:03:02:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
Workshop Code: 790 06325 000001
VIN: WAUZZZF41HA029523 License Plate:
Mileage: 70132km-43578mi Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 2B 42 44 46 52 5F 6C A5 BB BC
VIN: WAUZZZF41HA029523 Mileage: 70132km-43578miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CVNA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 022 HW: 04E 907 309 R
Component: R4 1.4l TFS H21 2848
Revision: 44H21000
Coding: 021900324324150834080000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM14TFS01104E906022 002006
ROD: EV_ECM14TFS01104E906022.rod
VCID: 5CE1946DF6A8793B6F3-8008
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 E HW: 8W0 907 379 J
Component: ESP9 Plus H06 0593
Coding: 04AA049908A40A9F15A3409300805292F6C19620201050A802004A496F8369
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHAU49X 012014
ROD: EV_ESP9BOSCHAU49X_012.rod
VCID: 47CB5B015F2E0AE3D21-8012
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 F HW: 8W0 820 043 F
Component: Klima Zone 3 H32 0071
Coding: 140800095544040D02000100880000000000000000000000000000000000
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 363526C528C4836BB97-8062
Fresh Air Blower Front:
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000916081
Relative humidity sensor in fresh air intake duct:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: F568433800PAG0MUFU02
Rear Climatronic Operating And Display Unit:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H34 0073
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 BC HW: 8W0 907 063 BC
Component: BCM1 MLBevo H13 0248
Coding: 80453142451800CD010487141B0C00B9110B3108000000000000000020001A2000410022025601
ASAM Dataset: EV_BCM1BOSCHAU736 016006
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 7DA7F9E94D72903338D-8028
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 160527 043 0813
Serial number: 894253?0301614802573
Coding: 5BC7F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 HW: 81A 955 555
Component: G397_RLFSS H06 0001
Serial number: 20043735X81A95555500
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 22 04 2016 00327585
Automatic Day Night Interior Mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105051611521227
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10178541
Convenience And Driver Assist Operating Unit:
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H16 0010
Serial number: 2616000057432004
Coding: 000000
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 HW: 8W0 959 655
Component: Airbag10.44 H72 0086
Serial number: 003M6004SAPC
Coding: AACCF0C00C800000585400F3C08C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 0655960518A4D3EB697-8052
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 442 061 506 16
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00C51F5EA224096
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 442 061 506 16
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00C71F5EA34B46K
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 805 16
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700B7209007382B/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 805 16
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700B72090075B33$
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 305 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500BB2090064C14%
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 305 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B72090066735$
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 305 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500BB2090061317P
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 442 430 906 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C31F5EA22C3AV
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 442 430 906 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00C31F5EA24027I
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E6C56844C36B797-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 940 A HW: 8W5 920 940 A
Component: MMA4M17BENUK H06 0363
Revision: 0339v7 Serial number: PY5F7VG6S
Coding: 24A4509028800600010069601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 3D2739E90DF2503378D-8068
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4M1 907 468 C HW: 4M1 907 468 A
Component: Gateway H15 0098
Revision: 4R040002 Serial number: 0244R00CF16615
Coding: 0301000100008E40260700000059001248080007000000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002060
ROD: EV_GatewCONTIAU736_002_AU73.rod
VCID: 372B2BC12FCE7A63A21-8062
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 8W0 951 523 C HW: 8W0 951 523 C
Component: J453 MFL H02 0002
Serial number: 20160607173239 02233
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 9421130604
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000113045016
Coding: 0000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 323D1AD5C4AC9F4B95F-8066
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 G HW: 8W0 959 593
Component: TSG FS 005 0052
Serial number: 0000206103454
Coding: 001F8A204001000000001082
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 4EC56E25B054DBAB917-801A
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X_002.rod
VCID: 40D9401D7A003DDB13B-8014
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 BA HW: 8W0 907 064 A
Component: BCM2 MLBevo 018 0327
Coding: 012D00002F100000630180000600000031020010004300500F04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 011012
ROD: EV_BCM2HellaAU736_011.rod
VCID: 7CA1F4ED5668993B0F3-8028
Sensor For Anti Theft Alarm System:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY161521UQP
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000066331801
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 592 G HW: 8W0 959 592
Component: TSG BFS 005 0052
Serial number: 0000205903256
Coding: 001F8A204001000000001080
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 4DC76929BD52E0B3E8D-8018
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8W0 035 192 A HW: 8W0 035 192 A
Component: MU-HS-LND-EU 045 0148
Serial number:
Coding: 01940101FF0A000213111101000A00102F0001C601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 34311CCD3EB8917B873-8060
Data medium:
Subsystem 1 - Part No SW: 8W0 919 866 C HW: -----------
Component: ECE 2016 --- 0009
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9GBH009UL
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 J HW: 8W0 919 614 J
Component: ControlUnit_B H21 0134
Serial number: APVAK112051600030336
1 Fault Found
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 70133 km
Date: 2020.12.19
Time: 14:47:27
Voltage terminal 30: 11.8 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: ERROR
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H18 0250
Coding: 0000000000000000000000
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33331FD13BB696439E9-8066
3 Faults Found
10490624 - No End-of-Line Programming
B2013 00 [009] - -
[Tip-TNF 197819]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 70133 km
Date: 2020.12.19
Time: 14:33:54
OFF
13636352 - Control module not coded
U1013 00 [009] - -
[ECU not coded]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 70133 km
Date: 2020.12.19
Time: 14:33:54
OFF
10489856 - No Basic Setting
B2010 00 [009] - -
[Tip-TNF 215372]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 59
Mileage: 70133 km
Date: 2020.12.19
Time: 14:33:54
OFF
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H14 0042
Coding: 0404090100000401024023A0A40000FC00F0C010C000
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3B2337F113E65E03469-806E
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.7V. VIgn 11.8V)-----
