Issues with coding Reverse Camera on 2016 Audi A4
bollaman
Hi Guys,
I've just purchased and 2016 Audi A4 B9 1.4 tfsi and I am having issues with a Reverse Camera Retrofit.
The camera was purchased from Carlise Audi's eBay store and came with instructions and OEM harness.
The issue I'm having is with the adaption and coding of the camera. When trying to enable VPS in 5F I keep getting request out of range using VCDS. It also looks as though the camera module isn't coded, but when trying to code I get: Coding Rejected. Error 22: Conditions not correct or request sequence error.
It appears as though I have also messed up the coding for 5f and get a coding error on that too (see full scan).
I've attached a full scan below and was wondering if anyone has come across similar issues and would be able to help. Thanks in advance
Code:
Saturday,19,December,2020,15:03:02:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
Workshop Code: 790 06325 000001
VIN: WAUZZZF41HA029523   License Plate:
Mileage: 70132km-43578mi   Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 2B 42 44 46 52 5F 6C A5 BB BC
VIN: WAUZZZF41HA029523   Mileage: 70132km-43578miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CVNA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 022     HW: 04E 907 309 R
   Component: R4 1.4l TFS   H21 2848
   Revision: 44H21000
   Coding: 021900324324150834080000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM14TFS01104E906022 002006
   ROD: EV_ECM14TFS01104E906022.rod
   VCID: 5CE1946DF6A8793B6F3-8008
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 04AA049908A40A9F15A3409300805292F6C19620201050A802004A496F8369
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 47CB5B015F2E0AE3D21-8012
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
   Component: Klima Zone 3  H32 0071
   Coding: 140800095544040D02000100880000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_AirCondiBHTCAU491 001013
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 363526C528C4836BB97-8062
   Fresh Air Blower Front:
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000916081
   Relative humidity sensor in fresh air intake duct:
   Subsystem 2 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: F568433800PAG0MUFU02
   Rear Climatronic Operating And Display Unit:
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H34 0073
Address 09: Cent. Elect. (J519)       Labels:* None
   Part No SW: 8W0 907 063 BC    HW: 8W0 907 063 BC
   Component: BCM1 MLBevo   H13 0248
   Coding: 80453142451800CD010487141B0C00B9110B3108000000000000000020001A2000410022025601
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: EV_BCM1BOSCHAU736_016.rod
   VCID: 7DA7F9E94D72903338D-8028
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 160527  043 0813
   Serial number: 894253?0301614802573
   Coding: 5BC7F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555     HW: 81A 955 555
   Component: G397_RLFSS  H06 0001
   Serial number: 20043735X81A95555500
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 22 04 2016  00327585
   Automatic Day Night Interior Mirror:
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Component: Y7_Innenspieg  H09 0002
   Serial number: GX1CE105051611521227
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10178541
   Convenience And Driver Assist Operating Unit:
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H16 0010
   Serial number: 2616000057432004
   Coding: 000000
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H72 0086
   Serial number: 003M6004SAPC
   Coding: AACCF0C00C800000585400F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 0655960518A4D3EB697-8052
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 442 061 506 16
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00C51F5EA224096
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 442 061 506 16
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00C71F5EA34B46K
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 805 16
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700B7209007382B/
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 805 16
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527700B72090075B33$
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 305 16
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500BB2090064C14%
   Coding: 2D2D2D
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 305 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500B72090066735$
   Coding: 2D2D2D
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 305 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500BB2090061317P
   Coding: 2D2D2D
   Pedestrian Protection Driver 2:
   Subsystem 8 - Part No SW: -----------    HW: 442 430 906 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00C31F5EA22C3AV
   Coding: 2D2D2D
   Pedestrian Protection Passenger 2:
   Subsystem 9 - Part No SW: -----------    HW: 442 430 906 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C31F5EA24027I
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 4M0-907-129.clb
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   Component: Lenks.Modul   H11 0009
   ASAM Dataset: EV_SMLSKLOAU736 006008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B5E6C56844C36B797-8022
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 940 A    HW: 8W5 920 940 A
   Component: MMA4M17BENUK  H06 0363
   Revision: 0339v7      Serial number:    PY5F7VG6S
   Coding: 24A4509028800600010069601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 3D2739E90DF2503378D-8068
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
   Component: Gateway       H15 0098
   Revision: 4R040002    Serial number: 0244R00CF16615
   Coding: 0301000100008E40260700000059001248080007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002060
   ROD: EV_GatewCONTIAU736_002_AU73.rod
   VCID: 372B2BC12FCE7A63A21-8062
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 8W0 951 523 C    HW: 8W0 951 523 C
   Component: J453 MFL  H02 0002
   Serial number: 20160607173239 02233
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Component: J367-BDMHella  H10 9070
   Serial number: 9421130604
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000113045016
   Coding: 0000000000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323D1AD5C4AC9F4B95F-8066
Address 42: Door Elect, Driver (J386)       Labels:* None
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000206103454
   Coding: 001F8A204001000000001082
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 4EC56E25B054DBAB917-801A
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40D9401D7A003DDB13B-8014
Address 46: Central Conv. (J393)       Labels:* None
   Part No SW: 8W0 907 064 BA    HW: 8W0 907 064 A
   Component: BCM2 MLBevo   018 0327
   Coding: 012D00002F100000630180000600000031020010004300500F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011.rod
   VCID: 7CA1F4ED5668993B0F3-8028
   Sensor For Anti Theft Alarm System:
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY161521UQP
   Alarm horn:
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066331801
Address 52: Door Elect, Pass. (J387)       Labels:* None
   Part No SW: 8W0 959 592 G    HW: 8W0 959 592
   Component: TSG BFS       005 0052
   Serial number: 0000205903256
   Coding: 001F8A204001000000001080
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 4DC76929BD52E0B3E8D-8018
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 A    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  045 0148
   Serial number:
   Coding: 01940101FF0A000213111101000A00102F0001C601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 34311CCD3EB8917B873-8060
   Data medium:
   Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
   Component: ECE 2016  --- 0009
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8W2 919 604     HW: 8W2 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9GBH009UL
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
   Component: ControlUnit_B  H21 0134
   Serial number: APVAK112051600030336
1 Fault Found
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 70133 km
                    Date: 2020.12.19
                    Time: 14:47:27
                    Voltage terminal 30: 11.8 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: ERROR
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H18 0250
   Coding: 0000000000000000000000
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33331FD13BB696439E9-8066
3 Faults Found
10490624 - No End-of-Line Programming
          B2013 00 [009] - -
          [Tip-TNF 197819]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 70133 km
                    Date: 2020.12.19
                    Time: 14:33:54
                    OFF
13636352 - Control module not coded
          U1013 00 [009] - -
          [ECU not coded]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 70133 km
                    Date: 2020.12.19
                    Time: 14:33:54
                    OFF
10489856 - No Basic Setting
          B2010 00 [009] - -
          [Tip-TNF 215372]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 70133 km
                    Date: 2020.12.19
                    Time: 14:33:54
                    OFF
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H14 0042
   Coding: 0404090100000401024023A0A40000FC00F0C010C000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3B2337F113E65E03469-806E
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.7V. VIgn 11.8V)-----
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
You will need a specialist application in order to parameterise the 6C camera module before it can be coded.
You should be able to change adaptation channels in 5F with no issues however.
where are you based?
