Issue with parking sensor after new bumper fitted
lukus89
Active Member
Hi guys,
I’ve recently had the RS6 front put on my A6.
Looks great but I’ve now got an intermittent false alarm with a parking sensor.
Some days it can be fine and others one of the sensors on the front left will scream as if something is right in front of it.
I’ve checked nothing is blocking it, and it’s fitted correctly.
The whole wiring loom was moved in one from old bumper to new.
Any ideas how to fix?
Thanks for the help
lukus89
Active Member
Here’s a pic
Rhyso
I had this when i fitted my RS6 grill. Make sure the sensor is clean and free of road salt :)
Rhyso
Yes :)
If you’ve cleaned it loads then it could be fault and one of those unfortunate coincidences when having the new front end fitted :(
Get it on VDCS or equivalent and see if it’s throwing up a fault code
lukus89
Active Member
Ok, just to update. Today there’s no issues so far, I haven’t had chance to scan the car yet but I’m wondering, what would make the fault inconsistent?
I get one of ours doing this sometimes when it' rained or front of the car is wet / dirty. Quick clean sorts it out
lukus89
Active Member
Just one inner one for me. Not sure why though?
Cleaned it thoroughly.
Wondering if some kind of software reset is best but I’m grasping?
It' the same one I get a false reading with occasionally. Normally water in my case.
Make sure it' got the rubber seal on the sensor it may effect the reading
lukus89
Active Member
Scanned with VCDS, no faults,
All week it’s not had a problem then today got loads of false alarms. It’s very very inconsistent.
Any ideas ?
Rhyso
Mine seems to coincide with rain; as if the sensor sits about 1/10mm to far in, water collects and sets it 0ff
lukus89
Active Member
That’s not a bad shout. Wonder how I can fix that... some kind of glue under the sensor? Something to stop the rain gathering
lukus89
Active Member
Ok so swapped sensor for a new one, no difference.
I’m now thinking weather it’s best to pay Audi to sort it but also thinking I haven’t really explored the issue with rain... I can’t fit the skirt around the sensor without removing the whole thing again which I don’t wanna do.
Any suggestions how I close the 1mm gap ?
Maybe a wipe of light grease around the edge of the sensor but that may also make it worst. I know body shops say they have to be careful spraying sensors. If the paint is too thick they have seen issues.
