maybe sameone have the same issue with this code? and that bank 2 camshaft A were is should be? because im confuse with this one Address 01: Engine (BDW) Labels:. 06E-910-552-BDW.clb Part No SW: 4F0 910 552 R HW: 4F0 907 552 D Component: 2.4l V6 MPI 0020 Revision: --H17--- Serial number: Coding: 0105000302070920 Shop #: WSC 02325 785 00200 VCID: 326B2338ADB6ABDF61-8066 3 Faults Found 000032 - Bank 2: Camshaft A (Intake) P0020 - 008 - Position Actuator Malfunction - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 3 Mileage: 233656 km Time Indication: 0 Date: 2020.05.01 Time: 15:40:13 Freeze Frame: RPM: 1216 /min Mass Air / Rev.: 103.6 mg/str Temperature: 73.5°C Overrun Bin. Bits: 00000000 Steering Angle: 114.27° 004407 - Fuel Trim: Bank 1 (Add) P1137 - 007 - System too Rich - Intermittent Freeze Frame: Fault Status: 00000010 Fault Priority: 6 Fault Frequency: 2 Reset counter: 38 Mileage: 233841 km Time Indication: 0 Date: 2020.05.06 Time: 17:15:53 Freeze Frame: RPM: 672 /min Mass Air / Rev.: 174.4 mg/str Temperature: 91.5°C Idle Time: 51.2 s Bin. Bits: 00000010 004409 - Fuel Trim: Bank 2 (Add) P1139 - 007 - System too Rich - Intermittent Freeze Frame: Fault Status: 00000010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 24 Mileage: 233841 km Time Indication: 0 Date: 2020.05.06 Time: 17:16:18 Freeze Frame: RPM: 736 /min Mass Air / Rev.: 250.7 mg/str Temperature: 100.5°C Idle Time: 2073.6 s Bin. Bits: 00000010 Readiness: 0000 0000
