Is this an S-Tronic characteristic?
mancdan
Manchester
Hi all, I have a 2009, B8 A4, 2.0TFSi Quattro S-Tronic with 103k miles.
Every now and then the S-Tronic box changes up to 7th gear too quickly, so I am in 7th gear at around 27mph.
It probably happens every few weeks, and I think it is probably when the car is cold, but can't be 100% certain on that.
95% of the time it acts fairly normal and is usually in 5th gear at around 30-35mph.
So is this just the S-Tronic box playing silly ******?
Are you getting panicky @mancdan at all these S tronic threads? :)
Mine doesn't do this but I do find in D it's really keen to change up early. For hilly roads I've taken to putting it in S to avoid this.
@scotty76 panicky is an understatement with this car I'm telling ya, it's been a money pit since I got it in October 2014:
Nov 13- Oil consumption issue fixed by Audi for free.
Nov 14 - front wheel bearing gone - £160.
Feb 15 - cam tensioner failed - £1800.
Aug 15 - cv boot gone - £75.
I just cannot trust this car at all, and always have a bad feeling with it.
Reactions: scotty76
Same here and same with my previous B8. Does it every so often (especially when cold) - probably the computer thinking you have enough momentum....but you don't!
Reactions: mancdan
Really sorry to hear that. We had a Ford Focus which eventually spent a week at the dealers. After that all trust was gone and we changed it. Sometimes you have to move on though I realise that may not be possible.
Reactions: mancdan
Cheers Scotty, I am thinking of getting rid after xmas and going back to a B7 or something older and cheaper to buy.
Like you rightly say, all trust goes in the car.
Reactions: scotty76
Ah but then there's the oil pickup issue on the B7 petrol turbos. And the oil pump issue on the diesels. :-D It's a nightmare. Maybe the warranty you asked about in another thread is the way forward? Push bike? :)
I'm also looking for a thread on which I commented where I noted my S tronic behaviour in a 30 mph limit. I'll hopefully find it soon.
Reactions: mancdan
@mancdan couldn't find the thread so instead I paid attention on the way to work. My 2014 car sticks solidly to D5 at 30mph. Even from cold.
Reactions: Scottyg
Cheers scotty76. Mine was ok this morning and has been for a few days. Its just very random when it changes up to 7th before 30mph.
I suppose the good thing is I don't have any of the other issues people have been reporting, so fingers crossed.
Reactions: V6 Quatt and scotty76
My car showed this trait every now and then, I thing it was the start of my problems with the 'box. It now has a brand new gearbox fitted, so hopefully won't do it again - for a while!
The 177 TDI quattro S-tronic I drive slips into 7th at 45mph, I'm going to redo the basic setting on the shift pattern and see if it helps any although I was told by an ex-VW tech it'll go back to the way it was as they're directed towards lowest revs in the firmware.
I can get more MPG (indicated not calculated) in M or S!
Sixpot, can I just ask how many miles your car had when the gearbox was replaced?
Thanks Darren, that's quite interesting that you get better mpg in M or S mode. I have often thought about driving it more in M mode but never do. Maybe I will try that for a while and see if the mpg does improve slightly.
