Is Audi Extended Warranty Worth It?
wolfie138
Just got an online quite out of curiousity, .£600 a year. seems a bit steep, but i'm not at the stage of them charging £60 just to look at something.
any opinions?
sidibear
Going with the flow.
Staff member
Moderator
Absolutely yes in my experience. Had 2 dual mass flywheels, oil cooler, aircon system, balance shaft, hex shaft and oil pump changed over the years and it only cost me the £250 excess.
wolfie138
bit disconcerting you needed all that!
which version did you go for, all parts or named items, and how did it compare to my £600 a year?
sidibear
Staff member
Moderator
I went for named items for £41 a month, paid by direct debit monthly so doesn't expire at 100K miles or 5 years. Mine is an 08 plate A4 Avant 2.0 tdi with 145k on the clock. Things go wrong so its best to be covered.
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
any opinions?
I wouldn't, didn't, haven't, and I've three Audi cars: 2010 TT, 2011 RS3 and 2013 A1.
In 50-years of motoring I've never bothered with a warranty from anyone... :superman:
Ghost
Booooooo!
Gold Supporter
I always think it's hard to tell somebody is a warranty worth it. but you got two good examples there from @sidibear & @45bvtc.
Pay £40/£50 monthly for peace of mind, but if something goes wrong or not you're still paying for it.
Or take a chance and if nothing goes wrong there is money in your pocket.
.. But if something goes wrong, it's your money to take your car where you choose.
You can still put the money away in a separate account if you wanted to?
I'm with haven't, wouldn't.
AndyT306
Moderator
Staff member
Moderator
my renewal on the quattro was 980, so i decided to self-insure, nothing has broken since
wolfie138
ta for the advice/opinions. i personally think - as w/ virtually everything from Audi - it's WAY overpriced. might turn out to bite my ar$e but i think i'll just put off and take it up if i start getting horrind noises from the engine or soemthing :-D
AndyT306
Moderator
Staff member
Moderator
i had my flywheel, starter motor and air con replaced in the first year of ownership, which is probably why my renewal was so expensive
sidibear
Staff member
Moderator
As an example just look at the posts about oil pump issues on the 2.0 tdi. Mine cost £250 excess to get everything done, I have seen prices around £2k+ for the same work. also the dual mass flywheels are around £1200 to change.
For me personally its worked out ok, and I get breakdown cover with it. Over the last five years it has cost me around £2500 in warranty fees and had around £6k+ worth of work done.
