D.C. Christopher
just remove the .txt extension! I couldn’t upload to A-S otherwise.
Only thing I can think of in addition to what you have already completed settings wise would be:
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz = On
There is something else to check but it's complicated. Change the above, delete all devices, reset MIB and test again.
just to confirm, you are resetting the MIB in-between changes? Long press on the power button and don't release until the unit powers off and back on againYeah, I noticed that one ... I think that’s for the MMI to join a wireless network (thus setting its network interface to client mode). I used that trick in my B8/B8.5 S5 cars to get out of having to use the SIM card (Audi Connect) to get online. So instead of your phone connecting to your car, your car connects to your phone!
But, hey, I’m desperate to get this to work so I’ll give this a try!
WelcomeNo dice! I’m pretty sure the underlying problem is the lack of 5GHz antennas in these cars. When my laptop connects to the car’s WiFi, it still shows 2.4GHz. I mean, you SAW all my settings. If they were actually being observed, there would be zero WiFi.
Thank you again for taking a look at this!
Welcome
when next with your car try this, turn on the vehicle and wait for the MIB to fully boot. Once loaded, from the menu screen press and hold the following two locations together until the unit reboots and enters "RED" engineering mode:
Once in the menu you should be able to browse for activation codes. Do not play with anything while browsing, not that much can be done tho. Can you take some photos of whats on your vehicle. I have a feeling that wireless ASI very very new vehicles might be licensed given that the adaptation changes have not worked.
- press and hold on the time in the top right
- press and hold the icon next to the time
Here you go!
00060F00 = Not sure what this is
00060800 = Apple CarPlay
00060900 = Android Auto
00040100 = Navigation
00070200 = Voice Commands for Navigation
00030000 = USB
00050000 = Bluetooth
02A100F0 = Navigation Data
indeedall I know is it’s all legal!
indeed
not sure what could be going on to be honest. personally I would return everything to stock, reset the MIB and then start over as this should work based on my experience.
Not given up yet, just need a car to play with. Am sure one will be in a soon as this lockdown is over.Man, why does everyone act like I’m speaking Greek?
Seriously though, it’s not supported in this particular car. They take the time to spell it out in the owner’s manual. A lot of people get confused because they see a face lift MMI and think “well, surely...” ... first of all, don’t call me Shirley.
But seriously, until I meet someone who has the same MY and model car and got it to work, there’s no point in wasting any more time. Everyone who got this to work had a different car: A3, A6, A7. Not sure how that A3 got in there. At this point the dongle is the cheaper option.
Thanks again, DJAlix, you’re awesome for giving this multiple tries!
My Sline A6 was built early Jan 2020 and does wireless CarPlay from the factory. If you want any scans just let me know. I’ve got ODB11 and VCP.
Uh? I thought all A6 C8's had dual touchscreens - lower climate control screen and upper MMI? Unless its different in US?Thank you for offering! If you have dual screens (not counting the virtual cockpit) or a 6/7/9, it’s not an issue. It’s models 5 and below with a single infotainment screen (no climate screen) that seem to have the issue. I mentioned elsewhere that they’ll probably unlock wireless CarPlay with Audi connect Plus (a mere $500/18 months plus data plan). We shall see!
Apologies , he did mention models 5. I need to visit Specsavers!
