intermittant suspension warning light
otter
Hi
I have a 2010 TTS and the suspension warning light has been coming on intermittently for the last 10 days...it is getting checked out at the weekend but before it goes into the garage I just wanted to hear about anyone elses experiences with Mag Ride failure, ie is it likely at 40,000 miles that I could be into new shocker(s) or could it just be a loose connector? Its not often I remember to switch on 'sport suspension' to be honest but if I use it now, the warning light takes longer to come on than if its switched off. Random? !
I would appreciate anyone's two penneth on the matter.
many thanks
Sunil
M666
I'm having same Issue on mk2 tts with only 25kmiles the mag ride warning light comes on then disappears after switch off re start
Did you get yours fixed ?
