Interior mirror
danielos77
Hi,
Do you know where you can turn off the interior mirror dimming?
I have a tinted rear window and it's already too dark
1Rockape
The only other way is to unplug then behind the plastic trim . It won't cause any faults unless you have high beam assist camera incorporated . If you have dimming wing mirrors they will also be deactivated
danielos77
Hi, this is not a solution to the problem for me as I need working exterior mirrors. I am looking for a solution to disable this option through coding
1Rockape
The mirrors will work for adjustment but won't dim . The interior mirror cant be coded . You could swap for one with the switch on the bottom . Have you a photo of your mirror
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Mirror is “dump” and only uses power and earth (in basic) so cannot be communicated with / coded. Put a bit of tape over the sensor on the passenger side of the mirror and that should sort it.
danielos77
My mirror
Rcord
If you want to disable only the interior mirror and still have exterior mirrors dimming, the only solution may be opening the mirror housing and disconnecting the interior mirror glass from the circuit board. I've worked on a mirror circuit board some time ago and it had simple flat type terminals connecting to the mirror glass so they could be disconnected without having to cut any wires, but I'm not sure it will be the same for you, as mine was a PFL mirror. I can post some pictures of the board in case you're interested.
Rcord
Please, I'll try
Wires come from the mirror glass and connect to flat terminals soldered on the circuit board. Both exterior and interior mirror glass are driven by the same Hexfet power transistor but they have independent voltage regulation circuitry, so I think if interior mirror glass works normally when exterior mirrors are disconnected, the other way around may work too.
Pictures below show the whole board with mirror glass disconnected (terminals on the board are marked in red circles) and part of the board with the glass connected.
1Rockape
I’ve had the facelift mirror open and can confirm the pco is the same 2 spade clips to the glass as in records photo
