Interior LEDs
Hi t8ups,
How much would lights be for front (main), rear (main), boot and number plate lights? (anyone upgraded the plate lights, any pics would be great!)
Is there any other additions anyone recommends? I don't have lights for the footwells nor door.
Hi Trups,
I have taken a couple of pics of the bulb and housing. The bulb is 42mm in length and has 12v 10w on the end.
Please let me know if these help:
Hi Dan, yes is it just the 1 bulb it requires? is that all thats in there for the interior?
Trups
Hi t8ups,
i take it you have the A4 then?
for the front do you have the main lights with spot lamps and then in the rear its a main light with 1 button in the middle?
how about swapping out the glove box and the boot too?
plate lights make a big differance to the way the cars look.
this is the standard 2 led bulb i supply for the number plates.
please let me know about the roof lamps and i can give you the price of what you require.
trups
Hi buddy,
Sorry for the late response. You're spot on. I would require a swap out for the boot, not bothered about the glove compartment.
So that's a price for front replacement (with spots), the rear and boot. Then if I decide to go with the plates too, how much would they be in addition?
Do you also do clear white lights (error free) for the dimmed sidelights for the front?
Hi,
ok the front and rear dome lamps are £14 - 4 led's per bulb
front spot (map) lights - £5 - 5 leds per bulb
boot is £7
so the interior is £26
to add plate lamps they are £6 for the 2 led bulb, same as the A5 has.
postage is £1.52
i dont have any side lights in stock at the moment, ive been busy the last two weeks and these have been the most popular.
i will have some in stock in the new year tho.
any other questions then please ask.
thanks
Trups
Hey trups, are you able to supply the xenon headlight conversion kits for audi b7???? Thanks chris
Hi
I am looking for some LED bulbs to replace those inside my Audi A4 06 reg saloon, 2006 model.
I am looking for:
2x front map lights
2x rear map lights
2x interior dome lights
light for the inside of the boot.
I would like the LEDs to be as bright as possible. Could you advise me on what types/part numbers of bulbs I require and how much they would cost?
Many thanks!
Thinking of replacing my interior el-cheapo LEDs with white LEDs. Can you give me price & the bulb types for the above, ie
1) 2 x front map lights (2 individual switches)
2) Front main light (1 switch)
3) Rear main light (1 switch)
I'm useless at fitting anything to cars but I'm interested in upgrading the interior lights, my A4 doesn't even have a light on the passenger sunvisor. Would a mechanic do this or is it specialised?
Dave, what car do you have?
I can talk you through it on the phone, they are easy to fit once they are in front of you.
Trups
My LED kit arrived today with exterior bright whites also - now I need the weather and day light to fit them all :)
Cheers T8ups and will post a photo here when all done.
