Instrument cluster
BlueA6Avant
Just taken delivery of a 2016 A6 Avant 3.0TDI Black Ed, funding made my wait long but worthwhile :) I need to quite a bit of work to the car starting with removing the instrument cluster. Does somebody have instructions or can link me to a set please? Thank you.
BlueA6Avant
I suspect that you are right. I bought the vehicle with a disclosed intermittent issue where the dash blanks. I suspect a wire harness that may be pulling on a connector as this happens when the vehicle is travelling and seems associated with bumps in the road. A thread in Audizone suggested that a fastener may be missing. This is my first port of call as it’s a relatively straightforward fix.
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Remove trim from around cluster, 2 bolts at the bottom, remove cluster.
B5NUT
Well-Known Member
There is a known software issue with the dash panel, where in instrument panel goes blank. There was a software update from Audi to fix the issue, had it applied to my A6.
BlueA6Avant
Good call B5NUT, thank you. I’m an hour and a half from my Audi dealer here in Scotland, so I’ll check the software version first.
BlueA6Avant
I checked the software version (RMC_EU_P16092) with the Audi dealership and they confirmed dash issue resolved by this update. So, I’m back to square one as I don’t know which parts of the dash need removed or how to remove them: does anyone know where I could find these instructions please?
B5NUT
Well-Known Member
The dash update was independent to the MMI update, my MMI version never changed when the did the update. Also your version number starts with a P which should means it's the factory firmware that came with the car, and I believe if the update starts with a K then it's had an update at some point in time. Think the dealership is talking porkies!
