inside windscreen cleaning
martin1984
worcester
so now the cold weather has sort of set in my inside windsceeen seems fogger on start up has anyone tried rain-x anti fog does it work or any other products you can suggest.
thanks
Sent from my SM-G930F using Tapatalk
thanks
I tried it last year, it seemed to make it worse. But I'm bad at cleaning glass so may try again.
Sent from my SGP621 using Tapatalk
Reactions: martin1984
I use Autoglym Fast Glass, plus I always have my AC on auto.
Getting the interior glass clean clear and streak free is nigh on impossible for me. Can't master it!
well im taken a pop with the rain x anti fog as was 3squid in halfords so will ipdate after a week of use.
Use one of these to apply your glass cleaner onto , then hang another specific glass cleaning cloth over the pad to clean the residue off/dry the windscreen pretty easy, it's good for the hard to reach areas of the front and especially the rear screen of my saloon
Screenshot 20181114 140729
Reactions: cuke2u, martin1984 and Taxboy
Use one of these to apply your glass cleaner onto , then hang another specific glass cleaning cloth over the pad to clean the residue off/dry the windscreen pretty easy, it's good for the hard to reach areas of the front and especially the rear screen of my saloon View attachment 169934
I second this but there's still a small strip of my rear window I have to contort to reach by hand. Overall definitely worth getting.
Sent from my XT1032 using Tapatalk
Reactions: Jassyo06 and martin1984
I agree with using AC with heater and I usually clean the screen first with a degreaser then with a cleaner and a waffle towel. A few on this forum have said that most of the issues with the inside windscreen comes from the VOC from the dash. I have stopped using coatings on the dash and just clean with a damp towel.
I don't recommend RainX Anti Fog at all, I tried it by following the instructions to the letter and it just left smears everywhere, didn't make a difference to condensation and actually made the condensation look worse.
Auto glym glass Polish if you want an absolute streak free finish. We warned though. It drys to a power to buff off. So get a big old bath towel to put over the dash.
I do the inside and outside of my windows once a week with AutoGlym Fast Glass. It's quick and streak free .
I use this which has rave reviews from detailer’s, apply , wipe off , use any good glass cleaner , I use Chrome glass cleaner which is fantastic
B7A97DB0 6BB3 4831 99A4 58AF03431443
3B6E80D7 C89A 423F A139 1D56588EE3CE
Reactions: Corb2000
While on the subject of windows, anyone have any idea how to remove that weird layer of greasy whatever that always appears on my windscreen throughout the winter months?
I had it worse on previous car and tried all sorts of things even like vinegar and isopropyl etc but I could never really get rid of it entirely.
Neat washing up liquid works for me
Thanks, I was afraid to try that incase it just smeared everywhere and made it worse .
Na its good at getting all the crud off just use kitchen roll to wipe off as much as poss before adding water or glass cleaner to finish it off.
Thanks, I'll give it a go.
I use 3M aerosol glass cleaner onto a micro fibre pad as it gets a bit messy with the foam. Then wipe off and polish with another dry pad. Not sure it helps with anti misting but cleans well.
I wouldn't recommend kitchen roll as there are often chemicals in the paper to aid absorbancy which can smear. If you want to use paper try the blue commercial stuff if you can get it or alternatively just a microfiber before finishing off with glass cleaner and a specialist glass cloth. Another tip I've found useful is to only wipe in one direction, that way you are not moving any dirt back onto a clean area
Sent from my SM-T800 using Tapatalk
Reactions: Simon Lowe
One other thing ive done in the past is used my clay bar on all my glass if you have one
Yea micro cloth prib better than kitchen roll to be honest
