  2. Dismiss Notice
I'm on my 7th rear air suspension bag in 18 months - Why !?
Scrapingalong Jun 30, 2020
  1. Scrapingalong
    Scrapingalong Registered User
    Well looked-after 2006 Allroad 3.0 TDI.
    Does anyone know what could cause a rear suspension airbag to burst (and I don't mean develop a slight leak)?
    I have had a saga all around the car, but the front seems to be sorted by: New pipes, new compressor, new valve block, new Bilstein struts (after the originals and the Chinese ones failed).
    So to the REAR !
    - Original bags failed
    - Replace with decent quality from Germany
    - These failed
    - Replace with better quality Dunlop ones
    - One of these has failed
    - Now that Bilstein make rear ones I'm ordering one of theirs.
    MY QUESTION - is there anything that can cause over-pressure / pressure not switching off / imbalanced pressure etc that could cause a premature failure as it can't be a coincidence any more ?
    Also replacing the rear pipes and might as well do the rear level sensor.
    HELP?
  2. Avatar
    snack-media
    Advertisement
  3. RS3 S.
    RS3 S. Registered User
    1,108
    551
    Sounds like a bit of a nightmare for you !!!. Can't help with the answer unfortunately but hope i don't have the same problems with mine. :sob:
  4. Scrapingalong
    Thanks for the sympathy !
    What really frustrates me is that I can never get to 'root cause', despite it going into two different Audi VW specialists who check what they can and repair the fault at the time - one of these specialists has a top reputation for high quality Audi tuning & servicing.
    My understanding is that this generation of air suspension is quite basic, so the fault diagnosis side is very limited - so there's no point in biting the bullet and taking it into an Audi dealer at £120 an hour to be told the airbag has blown... and ...?
  5. RS3 S.
    1,108
    551
    .........i feel your pain :cry: nothing worse than a problem you can't seem to solve. My car is on a 16 plate so a bit newer than your's but i hope i do not get the same a bit further down the road of ownership?.
    Hope you get it sorted soon.:smiley:
  6. Scrapingalong
    The irony is that my Subaru Impreza has just turned 20 years old and despite it being 'a bit quick', it keeps on going from service to service.
    Its had more use in the last year than the last 5 because of the Allroad !
  7. Scrapingalong
    Can anyone help me?
  8. Scrapingalong
    Garage can find nothing - faults checked, readings checked, lines and connectors checked, soap tested.
    If they don't know then I am going to buy rear struts and see if that helps 'take the weight' off the air springs
  9. JohnnieWalker
    JohnnieWalker Registered User
    44
    14
    I don't know anything about air suspension, however sometimes it's best to 'stand back' from the situation and look at the most likely cause, to me it seems unlikely that the air bags themselves are the problem.
    Surely it's more likely to be to be another part on the car causing them to burst, have they all failed in the same way?
    I'd think either something is physically causing damage to the air bags, causing them to fail, or it's a pump/sensor issue causing them to be over inflated.
