Illuminated Door Scuff Plates
jrumball
I bought a set of OEM (8V4071300) illuminated scuff plates from here they were about a third of the price of what I had seen them in other places and battery powered so no wiring .
https://www.ebay.co.uk/itm/Audi-A3-8V-Sportback-Limousine-beleuchtete-Einstiegsleisten-8V4071300/272330403835?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
The kit comes with both front and rear trims batteries magnets and a wooden wedge to aid in removing the original trim.
They were easy to install and look smart. Though hard to get good exposure with stupid phone camera =)
My car only had trim on the front doors. This came off easily with the aid of the wooden wedge, I worked it along the closest edge of the trim and then leavened it up from the front, this stopped me from bending it . I did not make too much of an effort to remove all of the previous foam adhesive as the new adhesive pads didn't really foul on where they were before.
The manual that comes with the trim gives dimensions of where to put the trim but it is hard to judge so I marked the original trim and centerer the new trim on it.
On the rear I placed them where the sill was flattest.
The magnets to activate the LEDs are easy to install just place them on the trim and close the door and the magnet sticks in place on the underside of the door you then just stick the plastic retainer over it.
It looks like the batteries will be easy to replace as the sticky pads are the only part clipped to the trim, they are also on a timer so hopefully will last a reasonable amount of time.
Adam14
Ooooh these look cool! I wonder if they do ones that say S3 as opposed to just S. Are the trims not hard wired for the lighting power?
Sent from my SM-G965F using Tapatalk
Adam14
I had a quick look, there's a few but job to tell if they'd fit or genuine. I'm happy with the default ones, was more if they were "readily available" it'd be a nice upgrade, like what you did with yours. Looks great btw!
jrumball
They seem to be a standard size the manual that came with them had instructions for A1, A3, and A4 along with 3 and 5 door variants
Adam14
Interesting! Thanks for the heads up. I did see a couple for the 8P sportback, which wouldn't be much use for the 8V Saloon I'm not overly fussed, seems quite a high price for them. Thanks for the info though!
jrumball
Completely understand I thought ~ £100 was bit on the steep side would of never of had them @ over £300 !
Adam14
Are these not standard on the s3? Every fl I’ve seen has these.
Yup I got those. But was after where the S logo is, it saying S3. As to me just the S can quickly be misread as S line (not that there's anything wrong with that) just personal preference. I have an S3 so want to show it off at the end of the day.
Albert Fong
S3BE2018
Ahhh I see now. Think after market is the only way. Good thing is the wiring is there already for you.
Thing is where do you stop. The steering wheel and gear stick only shows S.
Adam14
You're a bad influence! The list only grows by day. For now I'm just focused on getting my detailing gear up to scratch! Think expensive mods will wait till I see what I decide at the end of my PCP term.
Albert Fong
S3BE2018
This forum is a bad influence. Got my list of mods already. Just need cash now :welcoming:
Mike Feldman
Member
I also got the door sills and love them. Where did you find e-TRON puddle lights?
Roberto1234
Hello, do you still have the installation manual? Can you upload or send me photos of the instructions? I did not get a manual with my shipping.
View attachment 166725 View attachment 166726
View attachment 166731 View attachment 166727
Dubjam
Moderator
Staff member
Moderator
Just installed the Quattro ones...got them on sale from Poole Audi, £90 for all four!
jrumball
Maybe I will look tomorrow, from memory, it was just clean the surfaces and make sure the magnet was in line with the scuff plate when the door closed ?
Dubjam
Moderator
Staff member
Moderator
Its not rocket science.
Using masking tape to mark where old ones are, or just the joining line of the interior trim as your guide point.
Remove old ones.
Clean old adhesive off and clean surface.
Clean bottom of door where magnet will go.
Fit new plates.
Remove masking tape and any guide points etc.
Put magnet on the section of plate where the light turns off, close door - the magnet then jumps onto the door.
Put sticky cover over magnet.
Job done.
Dubjam
Moderator
Staff member
Moderator
Thanks, thought it was specifically Poole Audi. Looks like it was only the quattro ones on sale
Poole Audi operate and own that website, so it is.
YEs, dosent look like there is much left, worth a call to them though
