About a couple of months ago my turbo when into limp mode, I assumed this was caused by sticking turbo vanes as the logs were indicating an overboost. I managed to clean the turbo with Mr Muscle turbo cleaner and this has 100% cured the limp mode problem.
One thing that concerns me since the turbo problem is the exhaust has been blowing a grey/white smoke with a blue tinge on most cold starts that gradually disappears as the car hits 90 degrees. It seems to come on when the turbo hits boost but can also be sometimes seen when the car is idling.
The car is not lacking in performance in any way and the turbo sounds quiet. Interestingly I took the car out for a long hard drive a couple of weekends ago and this completely fixed the problem only for it to return a few days later.
I have a gut feeling the turbo seals are leaking oil into the intercooler which then gets burnt off during driving and then it starts leaking again once the car is left overnight hence the recurring problem. Does this sound feasible?
I will note that the car is not using an excessive amount of oil and the coolant level has remained the same. The EGR is leaking oil slightly but this can't be cause can it?
Any suggestions guys?
