  2. Dismiss Notice
Hunter Wheel Alignment
jdp1962 Feb 25, 2014
  1. jdp1962
    jdp1962 Grumpy Old Man
    9,815
    4,369
    After getting new tyres put on last Friday, and seeing the additional wear on the inner shoulders of the old ones. I got a four-wheel alignment check done today. The nearest Hunter-equipped place is a BMW motorsport specialist about half a mile from the house. I took it in first thing this morning, and they did it on the spot; it took about an hour and a half. I've got a before and after printout; there was quite a lot in the red zone before, mostly front and rear toe.
    Now, everything is in the green zone, bar one exception, the left front camber. It's at -1.30 (correct setting is -1.05 with 0.23 tolerance so it's 0.02 outside maximum tolerance), but front camber is non-adjustable. Short of moving the subframe or fitting adjustable control arms, I'm stuck with it.
    Total cost £78.
  2. Avatar
    snack-media
    Advertisement
  3. A4_MaJiK
    A4_MaJiK Azeem
    910
    110
    43
    Had the same sort of outcome on mine, I believe the upper control arm bushes may be worn which is causing the camber to be pushed out of tolerance. Although saying that, 0.02 is barely anything.
  4. jdp1962
    9,815
    4,369
    I'm kinda thinking that way too. Let's hope we're right.
  5. Paul B7
    Paul B7 Registered User
    622
    34
    Similar issues with my 2.0tdi.
    Wheel alignment man says its a common problem on the A4,A6 , Passats and now showing up on the A5's.
    I am just living with it as it looks a potentially expensive and time consumming issue to sort.
  6. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User
    7,508
    3,768
    On the Passat B5.5 it is possible to move the subframe to balance up the camber readings across both sides, I presume it's the same on the Audi.
    If it's on one side only and quite a bit the car may have found a kerb at some time in the winter which has knocked it out.
    1.3 degrees is not excessive and a bit of camber helps turn in. As long as the tyre wear is reasonable I wouldn't worry about it.
    Karl.
  7. jdp1962
    9,815
    4,369
    Yeah, that's what the guy at BMSport said.
  8. Pat.
    Pat. Registered User
    JDP, You're on lowering springs? This'll introduce a bit of negative camber.
    As long as your toe settings are now correct and within tolerance, you should see a heck of a lot less inner shoulder wear :)
    jdp1962 likes this.
  9. Pat.
    This was my 'before' printout. I'd fitted the 45mm H&R springs and B5 perches a few weeks prior..
    jdp1962 likes this.
