  2. Dismiss Notice
Humming Noise
fafa Apr 16, 2018
  1. fafa
    fafa Member
    119
    My Dad was driving with me on a long journey this weekend and he pointed out that there was an unusual noise coming from the front of the car. It's a whirring/humming noise at the mid range that changes pitch with road speed not engine speed. A bit of online research and I think it might be the wheel bearing, is there any other thoughts on what it might be?
  2. Avatar
    snack-media
    Advertisement
  3. Jakes2514
    Jakes2514 A6 C7 AllRoad 3.0 TDI - Ibis White
    123
    96
    Depends on the humming but you are correct at looking at the final drive train, one thing also to consider is the covers on the bottom of certain cars. These sometimes come loose and start ‘catching’ the wind and vibrate accordingly. Simple to check bu getting under the car and having a look, while under there check the CV boots for cracks/leaks
    If its a wheel bearing it can be checked by checking the heat of the wheel once a journey is completed. A bearing that is going will start to produce more heat as friction increases, compare the opposing side wheels. Not a absolute accurate check but it worked for me in a Golf I used to have.
  4. fingermouse
    fingermouse thats me
    4,241
    198
    Just done a wheel bearing on our bitdi
  5. jetty
    jetty Active Member
    257
    72
    How much tread is left on your tyres ?
    If you are getting low I would replace those first (check tracking as well) - then look at bearings.
  6. fafa
    fafa Member
    119
    Update. It's in with the local garage for the ecu light from my other thread and he's said that this noise is the bearing. 160 to replace inc Vat. With the pump costing similar a couple of months ago I'm starting to wonder if it's time to change and put the extra I'm paying out in repairs towards a high monthly on a newer car.
  7. Daniel J.
    Daniel J. New Member
    Hello guys,
    I have somewhat similar problem on my 180kw Quattro with around 105t km (65t miles), that can be seen on a video I found on youtube (not mine car) -
    This buzzing/whining/whistle noise occurs only at speeds from like 80kmh to 120kmh (lets say 50mph to 80mph). It is in fact only noticable when cruising and keeping steady speed or slowly accelerating, but when you hammer it or do not push gas at all the noise almost disappears (other noises come to be more noticable). Shifting to other gears do not affect the tone or intensity, so it only is speed dependant (as it seems to me). In hwy speeds (in my country it is around 90 mph) I do not notice the noise, the worst scenario is quiet asphalt and cruising aroung 60-80mph...
    I would love to think it is wheel bearing, but I have not found a single video with bad WB making this high pitch sound... Any ideas? Differential bearings? ...
    Thank you for your inputs guys.
    PS: Sorry for my English - not native, but I hope it will do...
    Daniel J.
  8. fafa
    fafa Member
    119
    That doesn't sound like mine did.
  9. Daniel J.
    So I recorded my kind of whistle. Here it is...
  10. RuchanSnr
    RuchanSnr New Member
    I Daniel,
    did you ever find out what was causing the high pitch noise on your car ?
