Traveling home yesterday engine light came on then drop in power until the car shut itself off - was on the motorway so not great then had to spend over and hour on hard shoulder waiting for a tow to get me home as car wouldn't start.
Battery is fine I believe its a fueling issue - so I can hear the pump prime, had the Fuel filter off, tested it by blowing through to ensure not blocked and refitted the 'IN' feed and turned ignition and a nice stream of fuel comes through the 'out' so this is fine also. Im thinking it might be the HPFP that's failed and not fueling the engine - is there a way to check? DO I unscrew the big nut on the bottom of the pump which I assume is the in feed and see if fuel comes through? What else can I check? Thanks
