How to test Inlet manifold actuator??
Jonezy87
As above, how would I test if I have a split diaphragm? Haven't got a mitzvah etc so is there an easy way or diy test?
max69vk
Active Member
It's my birthday
Suck on the pipe, simple as that really
Jonezy87
If I suck should there be resistance?:flushed: Just as I seem to be able to keep sucking suggesting maybe the diaphragm is split?!
max69vk
Active Member
It's my birthday
If you sick on the pipe there should be some pressure resistance and the actuator should move, if you suck on the pipe & it's like sucking on a straw your diaphragm is split.
Jonezy87
That's good news then! Well kind of, least it's only a cheap part! May as well clean Egr and inlet manifold whilst at it!
Thanks for the info pal
