  2. Dismiss Notice
How to remove alloy scuff
sunshinewelly Nov 7, 2018
  1. sunshinewelly
    sunshinewelly Active Member
    272
    143
    43
    ******. Reversing out of a tight spot. Cheers considerate neighbour and his van and in doing so my wheel slipped off parralel down off kerb and it got scratched
    They are diamond cut. Really peeved off with myself
    First mark I have had on the alloys
    Can these be repaired at home or do I need a professional. If so what is likely cost
  2. Avatar
    snack-media
    Advertisement
  3. Kevin Gall
    Kevin Gall New Member
    29
    Following
    Sent from my SM-G950F using Tapatalk
  4. Riko0073
    Riko0073 Well-Known Member
    1,139
    1,011
    I think a photo would be useful to see the extent of damage.
  5. sunshinewelly
    272
    143
    43
  6. sunshinewelly
    272
    143
    43
    Is there any lacquer I can apply in the meantime as I assume as winter is coming that this may cause corrosion
  7. V6_Man
    V6_Man Moderator Staff Member Moderator VCDS Map User
    6,933
    13,975
    rasA4 likes this.
  8. sunshinewelly
    272
    143
    43
  9. rasA4
    rasA4 Four Rings Mafia Specialist
    3,781
    306
    V6_Man likes this.
  10. cosmicblue
    cosmicblue Well-Known Member
    756
    350
    If it's minor like that you can, carefully smooth the chewed rim back with 180 grade wet n dry paper followed by 360 and finally with 1200 grade which gives something similar to the original finish - then put some clear coat on the bare metal. Don't work with full sheets of the abrasive paper, tear small bits off and work slowly, don't rush or extend the area of damage, with patience it will end up looking massively better. Mercifully I only did it once on the black 20" Rotors on the RSQ3, but did make the fix invisible.
  11. cuke2u
    cuke2u Well-Known Member
    12,817
    5,222
    If you don't feel confident about doing it yourself then a professional repair would probably need the wheel to be sent off, as it is diamond cut. Cost is around £125-£150..
  12. Avatar
    snack-media
    Advertisement
  13. sunshinewelly
    272
    143
    43
    Here is a clearer daylight pic. Will get some suggested sanding paper and give it a go I wonder if a dremel could be used 20181108_081927.jpg
    MOA4B9 likes this.
  14. cosmicblue
    756
    350
    Dremel - probably, trouble with power tools is that stuff happens and goes wrong fast. You are working with a really soft material here, going slowly and carefully is the key and even by hand 15 minutes would suffice.
  15. rasA4
    3,781
    306
    +1
  16. Daniel1512
    Daniel1512 Member
    125
    22
    it can be done at home but you want get the diamond cut finish .. i had a similar problem on mine a guy came and re done the wheel scuff and you cant see it isnt diamond cut unless you know what you are looking at
  17. sunshinewelly
    272
    143
    43
    cheers everyone
    there seems conflicting views on the starting grit to be used. Some say 600 - some say lower.
  18. rasA4
    3,781
    306
    The higher the grit the finer the finish.
    V6_Man likes this.
  19. MOA4B9
    MOA4B9 Active Member
    251
    68
    I would attempt to get it smooth and even with hand files for metal or even files for finger nails. Gives you a lot of control and will get nice flat surfaces and sharp angles. After that finish with very fine sandpaper.
  20. hellodave
    hellodave Member
    93
    49
    Definately do able - you won't get it perfect doing a DIY, but good enough from a distance. I've done a couple on my S4 (bl**dy tight French car parks!) and about 10 on the wife's car
    If you've got standard S4 alloys they're part diamond cut and part painted - obviously painted bits will need touch up paint (or spray if you're ambitious).
    My method is similar to above using tiny pieces of wet paper - I start with 120 grit to get the worst out, then 400, 800, and finish with metal polish. Clean thoroughly then paint/lacquer. Be careful to only sand the damaged parts - tiny bits of paper and slow movements are best. Forget power tools - far higher risk of making things worse and doing it by hand doesn't take that long anyway (soft metal).
    Personally I wouldn't bother paying for a refurb unless I'm selling the car. Sod's law dictates I'd go and kerb the wheel again within a week (friend of mine did exactly that)!
    sunshinewelly and cosmicblue like this.
  21. sunshinewelly
    272
    143
    43
    Cheers everyone for the great tips
  22. cuke2u
    12,817
    5,222
  23. rasA4
    3,781
    306
  24. DaveM
    DaveM Member
    79
    I had my Volvo V60 diamond cut alloy kerb rash professionally repaired for just £60, I had to take the wheel to him when he was quiet. He took about 90 mins to repair it and you couldn't tell it had been damaged. Worth asking around the mobile repairers.
  25. sunshinewelly
    272
    143
    43
    decided to try and fix it myself and when i am close to selling the car then i will get them done as i am sure there will be other marks on the alloys by then
  26. rasA4
    3,781
    306
    Careful it could get worse as you don’t want corrosion to set in. Keep an eye on it.
  27. sunshinewelly
    272
    143
    43
    just wanted to thank the helpful people on this thread. Carried out the work myself using a combo of 400, 800 and 1200 grit paper and it now looks a lot better. I will probably spend a bit more time on it when we have a bit more dry weather but very happy with the result.
    rasA4 likes this.
  28. cosmicblue
    756
    350
    Well done and thanks for letting us know too..:innocent:
  29. rasA4
    3,781
    306
    Good one be sure to post up during and after pics
