How to install downpipe for Audi rs3 8v
WalterRS83
Hi guys, can anyone explain to me how to remove the stock downpipe from the car? Do I need to remove the front axle and driveshaft in order to install aftermarket downpipe ? Because one of the mechanic told me he need to remove my front axle and also the driveshaft only can remove my stock downpipe . Please need advice !!
Spaceman_RS3
Aoon had done his I believe you have to loosen the front subframe bolts without actually removing them to allow enough room to get downpipe out poss have to remove prop shaft too but best to message him
WalterRS83
Thanks bro I'll try to msg him .
ConS3
I'm all for a DP, but what's the point when there are next to no Stage 2 tunes available? You're really not getting any advantage or gain from a larger DP unless you reflash. Stage 1 tunes will not incorporate the added gains from a DP.
In fact, I fear the car may run worse with a DP and no corresponding flash to leverage it.
Rocketer
Although it should give some horses because catback and decats gives some because of better flow and dp is the best of these three.
