  2. Dismiss Notice
How old is my MMI and maps?
DarkShadow May 30, 2018
  1. DarkShadow
    DarkShadow Registered User
    98
    32
    Hi guys,
    I'm new to the world of MMI and updating.
    1. How old is my software?
    2. Is there a changelog I can view?
    3. How can I update both MMI and maps, does this cost?
  2. Avatar
    snack-media
    Advertisement
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User
    5,107
    1,248
    1. About 4 years old
    2. No (Audi never release this information)
    3. illegal web downloads (could brick your system but free). Your local Audi dealer. Try business members on here.
  4. RJ-8V
    RJ-8V Registered User
    749
    184
    43
    It depends on from where you download it and which file. If you download a good the firmware there wont be any problems updating your MMI.
    Although i advice that you skip Bose/B&O update file.
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  5. B5NUT
    5,107
    1,248
    Which is what I'm taking about, it's an update and it can fail, regardless of the source. I've had failed modules over the years even using genuine disks. Also the map activation is a hack and the files are not generated by Audi. Also avoid anything that has the name "Kufatec map activation" that will brick your 5F module.
  6. RJ-8V
    749
    184
    43
    The reason why you have to skip Bose/B&O because you need to reparametrise your amp after update otherwise your sound will be messed up :)
  7. B5NUT
    5,107
    1,248
    Yes I know, but if you have access to VCP or ODIS this can be fixed after the update.
    RJ-8V likes this.
  8. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,332
    4,831
    1. How old is my software? = 2014/2015
    2. Is there a changelog I can view? = Audi do not publish change logs however as you have MMI3G+ there is a big change in P0700 (or one of the 700 range updates) which allows you to assign telephone and data functions to both a connected phone and a SIM card.
    3. How can I update both MMI and maps, does this cost? feel free to drop me a message.
  9. paultaylor
    paultaylor Registered User
    383
    25
    I’ve just got a dec 14 C7 3.0tdi 272
    I’ve been trying to update the MMI and when I put a SIM card in with a data package I ran some updates etc.
    I’ve loaded the 2017 maps onto an SD card but it wouldn’t read it.
    Aside from that as per photo below have the maps updated themselves via 4G?
  10. DJAlix
    6,332
    4,831
    Can you most the details from your MMI "version information" screen?
  11. paultaylor
    383
    25
  12. Avatar
    snack-media
    Advertisement
  13. RJ-8V
    749
    184
    43
    You have MIB2, there are update sd cards for it.
  14. paultaylor
    383
    25
    Thanks.
    I’m still confused how the Ireland maps got to update to 2017 without the sd card
  15. DarkShadow
    98
    32
    Have you done this yourself? How has your experience been?
  16. RJ-8V
    749
    184
    43
    I do it daily :)
    If you don't have vcp or odis, then skip the Bose/B&O. If you at least have vcp, then you can reparametrise the amp.
  17. Ex-4/73-Bty-RA
    Ex-4/73-Bty-RA Registered User
    Sorry to jump in but i've just bought a new to me 2014 A6 which has the optional MMI Nav plus, can you please give me the same info? many thanks
  18. DJAlix
    6,332
    4,831
    MMI3G+ with 2014 (Q2) Firmware and Navigation Data
    Ex-4/73-Bty-RA likes this.
  19. RJ-8V
    749
    184
    43
    Upgrade it to k1001 and map 6.26.1
  20. Ex-4/73-Bty-RA
    many thanks for that, any idea how i can go about it, like i say first time i've owned an audi. thanks again
  21. RJ-8V
    749
    184
    43
    Contact the dealership or look for someone who can update it for you.
  22. B5NUT
    5,107
    1,248
    There a a few business on the forum that may be able to help Audi Retriofits, JMB Retrofits, NHN & VAG Car Coding. Check the Site Sponsors and Banner Advertisers section.
  23. Rhyso
    Rhyso Registered User
    1,818
    485
    @DJAlix at VAG Car Coding helped me upgrade my maps and firmware so can vouch for him :)
