  2. Dismiss Notice
How long to warm up
paddy Jan 4, 2021
  1. paddy
    paddy Registered User
    6,818
    907
    With temps around 5c i find i need to do about 8 miles to get the gauge up to 90c...Seems like quite a long way. Once at 90 it holds it spot on , traffic or Motorway. Until then the heater is useless, am i just getting old :)
  2. Avatar
    snack-media
    Advertisement
  3. Gazwould
    Gazwould Registered User
    7,807
    3,158
    Sounds like thermostat , but what's your coolant capacity ?
  4. LEE69
    LEE69 07 170 DSG
    2,885
    542
    If it holding 90 I'd say it was and your old age, want my diesel? Takes an age haha, especially if not under load
    NHN likes this.
  5. ab1702
    ab1702 Registered User
    893
    263
    If it’s getting to 90 and staying there then it’s just because of the cold temps. If the stat was no good then it wouldn’t get to 90 or it would be up and down.
    Sibmets likes this.
  6. den911
    den911 Registered User
    179
    13
    -3 to +1 at the moment when i set off for work at 5.30am ,my first 6 miles is 30mph , the oil temp is at 62c when i hit the motorway on 6 miles then coolant temp hits 90c after a couple of miles on motorway and stays there..So aprox 8 miles for me (new thermostat housing last year)
  7. aqibi2000
    aqibi2000 Registered User
    1,045
    179
    with an EGR delete it triples the time when on low load
    Jay Drury likes this.
  8. Daveyonthemove
    Daveyonthemove Well-Known Member VCDS Map User
    1,827
    624
    Sounds about right to me. My temp only starts to move after about 1 mile of slow driving, and is rarely at 90 before 6 miles.
    That's with a brand new thermostat fitted at the end of summer and fresh coolant.
    paddy likes this.
  9. Gazwould
    7,807
    3,158
    That's what I absorbed and put up with for 6.5 years , then a new thermostat was put in and it gets to 90° like a rocket ( 1.9 tdi AVF ) reduced smoke opacity further .
    aqibi2000 likes this.
  10. SootySport
    SootySport Registered User
    4,229
    1,140
    Same here with a 2.0 TSI. Luckily it’s the Mrs. that drives it every day to the coal face while I’m tucked up in a warm bed .
    paddy likes this.
  11. aqibi2000
    1,045
    179
    Will give it a pop this weekend, cheers.
    Been like this for 4 winters now
  12. Avatar
    snack-media
    Advertisement
  13. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,203
    930
    Today i sat in mine for at least 8mins ( idle ) before it got to 80% and 10mins to get to 90
  14. abmat
    abmat Active Member VCDS Map User
    980
    218
    43
    I get nice warm air after about 3 miles and engine fully warm at about 6.
  15. aqibi2000
    1,045
    179
    Just a reminder we care about oil temp reaching 90 not the coolant, observe the DIS
  16. abmat
    980
    218
    43
    Would do if I had that function
  17. aqibi2000
    1,045
    179
    Cheap obd2 scanner and free app
  18. LEE69
    LEE69 07 170 DSG
    2,885
    542
    Spot on! Takes about twice as long for the oil to get to 90, as the coolant does
  19. samisnake
    samisnake Registered User
    864
    382
    thinking out loud, why would the oil temp be more important than the coolant temp?
    oil is multigrade, itll do its job whether its hot or cold. the coolant temp is an indicator of the temp of the block. colder coolant=cold engine=more friction as cold metal contracts and hot metal expands.
    ch1z64 likes this.
  20. S.
    S. Save the manuals
    2,333
    697
    Lower the oil temperature - lower the viscosity meaning more fluid particle friction. Oil paricles will move slower and the lubrication won't be as efficient as it would be on working temperatures.
    But i doubt anyone is sitting on the rev limit all day long for this to cause premature component wear.
  21. nluk100
    nluk100 Registered User
    1,580
    334
    Maybe not all day long but you'd be surprised at the amount of drivers who rag it straight from cold and wonder why their engine burns oil later in life.
    S. and den911 like this.
  22. LEE69
    LEE69 07 170 DSG
    2,885
    542
    Some people just have no mechanical sympathy at all
    S. likes this.
  23. den911
    179
    13
    Spot on, i am under 2000rpm until i hit min 62c oil temp,always look after your engine and it will look after you ..This i do not because i am not 21 any more i have always done it more so on my diesels ..
  24. S.
    S. Save the manuals
    2,333
    697
    I know. I guess that's why nowdays engines have soft limiters in neutral and engine component protections that holds the power down before engine is up to 60-70 deg (if i got that right).
    Back to the OT i guess it's right there at about 15-20km of drive in colder weather to get it to temperature - but it's not steady. I guess it's new thermostats soon.
  25. ch1z64
    4,203
    930
    A bit off topic but not miles away how can i see coolant temp on my Dis, or am i just being a bit daft as all i see is a snowflake icon and temp which i am assuming is outside temp . Any help muchly appreicated ,
  26. aqibi2000
    1,045
    179
    Any one on here from a cold climate with an oil pressure gauge?
    Can you record us a video of cold start showing the oil pressure gauge when the oil is cold, so we can see how significantly the oil pressure changes compared to when the oil temperature reaches 90 degree.
    With oil temperature increase the oil viscosity decreases == better flow between the bearing surfaces
  27. abmat
    980
    218
    43
    Do you mean oil temp?
  28. aqibi2000
    1,045
    179
    Can’t delete this posted by mistake
  29. ch1z64
    4,203
    930
    I can see the oil temp rise on the gauge but in post 13 member mentions coolant ( my understanding is he means u can see thst on Dis )
  30. Daveyonthemove
    1,827
    624
    Coolant temp is the permanent dial on the dash next to the fuel gauge. It's indicated by the needle and starts at 60c on the left with 90c in the middle (where you want yours to sit at) and 120c on the right.
    Oil temp is hidden in DIS menu.
  31. abmat
    980
    218
    43
    pretty sure gauge is water.
  32. abmat
    980
    218
    43
    this is only on the FL (white dash) cars right?
  33. Avatar
    snack-media
    Advertisement
  34. ch1z64
    4,203
    930
    Cheers ears just so i knew what waa what . Bulbs working great mate good shout
    Daveyonthemove likes this.
  35. ch1z64
    4,203
    930
    Cheers ears aa i have FL
  36. aqibi2000
    1,045
    179
    I have Oil temp with red cluster (DIS)
  37. Daveyonthemove
    1,827
    624
    Mine is 2006 S3, so one of the early ones.
  38. abmat
    980
    218
    43
    Where is it? I’ve never seen it.
  39. LEE69
    LEE69 07 170 DSG
    2,885
    542
    You need to go through the menu with the buttons on the end of the stalk
    I had it on my Pre FL red dials and now my FL wite ones
  40. abmat
    980
    218
    43
    I know how to use it. I just don’t have oil temp. I was wondering if it had to be enabled with vcds.
    LEE69 likes this.
  41. LEE69
    LEE69 07 170 DSG
    2,885
    542
    No idea sorry, mine was already there.
  42. LEE69
    LEE69 07 170 DSG
    2,885
    542
    Could try this
    http://www.audienthusiasts.com/VagComDIS.html
    Enabling Lap Timer on MY2010+
    *Oil temperature will be enabled as well:
    [17 - Instruments]
    [Coding - 07] -> Long Coding Helper -> Byte 1 Bit 3 change from 0 to 1
    Or Check the box for "Lap Timer active" if available.
  43. abmat
    980
    218
    43
    cheers. I’ll give that a go. I did it on my a6 but never looked on the A3.
