Hi Everyone,
After some advice / opinions on how to control tyre pressures. I have the live TPMS on my car, which is how I know temps / pressures all the time.
So obviously the common thing or recommended process is to inflate the tyres when cold. I’ve no idea why but my dealer inflated all tyres to 40psi on all 4-corners, I was told directly that they were recommending to all be the same.. needless to say I had a shock when I checked the door, 39 front and 35 rear is what is recommended for the staggered wheel setup with minimal load. I drove for 1500 miles like this because they hadn’t dropped, doh!
Anyway my local digital compressor is 3 miles away, during which time the tyres temps only climbed 2 degrees on 30mph roads only.
When sat and cold, my pressures drop to 36psi on the front and climb to 39.5psi when warm. My rears seem to be sat on 36.5psi when cold and warm.
Today when pulling out of the garage I had 36.5psi on the front, within a mile or so I had a warning that the car had detected a wheel change and the pressures had climbed from 36.5psi to 39psi, I’m not sure if that is why the car was led to believe there had been a wheel change?.. but the car has been driven like this for a week...
I’ve still not reset it, I checked the tyres when arriving at work and left the warning on inrentionally to remind me to check visually in the morning, but I’ve had no pressure loss according to TPMS.
I guess my real question is, shouldn’t we be checking tyre pressures when they are warm? Because as soon as they warm, the pressures climb. When I’m inflating them cold, the pressures end up showing 3psi under what I inflated them too according to TPMS.
I’m considering trying the Nitrogen, I believe I can get it done for a little under a fiver a corner locally and in theory the pressures will remain more consistent and I won’t lose any pressure over long periods of time?
Thanks in advance for some advice.
Matt.
Matt.
