m rol
- Joined
- May 15, 2017
- Messages
- 211
- Reaction score
- 28
- Points
- 28
My car a 2014 a3 8v with virtual cockpit and 8v1035035 mib2 (hacked unit)
As my car does not have a mib2 audi connect subsciption (duh) i want to bypass the audi connect feature, like the a4 canadian spec tread.
https://www.audiworld.com/forums/a4...oogle-earth-traffic-canada-spec-audi-2912779/
Tried the A4 google earth funktion but cannot make it work....
Checked all the items in adaptation and make them the same. I am also able to activate the client funktion and search for wifi hotspots. Does anybody has made it work? How?
Thanks in advance!
Adaption:
To enable Google Earth (this will require using your mobile phone's data connection as hotspot):
Step 1: Set the following adaptation in module 5F (this can be done by VagCOM HEX-CAN-USB or OBDEleven) :
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts - ON
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other - ON
IDE03471-ENG117843-Vehicle configuration-my_audi - ON
IDE03471-ENG117845-Vehicle configuration-online_dictation - ON
IDE03471-ENG127495-Vehicle configuration-online_media - ON
IDE03471-ENG117840-Vehicle configuration-online_navigation - ON
IDE03471-ENG117837-Vehicle configuration-online_POI - ON
IDE03471-ENG117838-Vehicle configuration-online_POI_voice - ON
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services - ON
IDE03471-ENG117841-Vehicle configuration-online_street_view - ON
IDE03471-ENG117844-Vehicle configuration-picture_navi - ON
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag - NO_REGION
IDE03471-ENG117836-Vehicle configuration-VZAPro - ON
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI - ON (only becomes active with internal sim off)
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot - ON
IDE03471-ENG117846-Vehicle configuration-remote_HMI - OFF (this turns the audi connect option off in mmi.
Step 2: Restart MMI
Once you've made the above changes, RESET MMI by pushing and holding the toggle to NAV and RADIO at the same time, then press the center **** to restart
While MMI restarts, turn on your mobile phone's WiFi Hotspot
Step 3:
Go to Settings in MMI > Connection Manager > Configure your WiFi Settings in MMI to connect to your phone's hotspot
Step 4:
Go to Navi/Map > Click to the 'Right' Option button > Select Map Settings
Under Display > Click and Select Google Earth
If you've configured a successful WiFi connection, Google Earth should load within 20secs or so
Thanks in advance!
Adaption:
Step 2: Restart MMI
Step 3:
Step 4:
