how can i make steering lighter via vag-com
vw754 May 18, 2009
  1. vw754
    vw754 vorsprung Durch Technik
    2,362
    60
    Ive heard on the A3 (8P) you can set the steering wheel via vag-com so it become lighter,any one know how to do this?
    I fitted 18'' s-line wheels,lowered the car 25mm,fitted new track rod ends it was ok,then i had 4 wheel alignment done and now steering is slightly heavier,tracking was out (obviously after new track ends and lowering) is it quite normal to go heavier,its not very heavy but you can tell,ive checked tyre pressures they ok.
    If any one can guide me how to adjust steering through vag-com to set it so its lighter please let me know thanks.
  2. Avatar
    Google AdSense Advertisement
  3. Dandle
    Dandle Member
    852
    Depends how old the car is. If it an 07 or later then you cant adjust the steering boost.
    More info here. I found 3 to improve the steering nicely.
  4. kaz219
    kaz219 Active Member
    1,808
    Mines on 3 bt was on 8 - awesome mod :D
    vw754 - car looks like its coming along nicely from the display pic ;)
  5. vw754
    2,362
    60
    :applaus:Thanks (kaz219):iagree:
  6. vw754
    2,362
    60
    yours was on 8 now 3 is it lower the number the lighter the wheel ?
    Must be heavy on 3 ????????
  7. Dandle
    Dandle Member
    852
    No by default most UK sport model cars are on 6. Three reduces the amount of power assistance and increases the feedback you get through the wheel.
  8. Wai-Fan
    Wai-Fan Member
    530
    Mine was on 10 when I checked mine! No wonder it felt dangerous! Had it put on 2 if I remember correctly. This is one of the most useful "mods" in my opinion, and also cheapest. Car feels so much better! Definitely worth doing. You should try it on different settings first before you keep it at that setting, just to see what feels best for you.
  9. vw754
    2,362
    60
    mine was set on 8 and ive now set it on 9 and it feels great not too light or too heavy,i can still feel good feedback through the wheel........you guys must have a heavy wheel ......all you guys are 5 and below:wtf:
  10. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Why on earth are you posting the same thing on 2 different threads in the same forum??
  11. Dandle
    Dandle Member
    852
    The problem with the steering is that its to over assisted and reduces the feedback you get. Putting it up to 9 your put more steering assit in. At 3 it isnt heavy but you can feel what the wheels are doing.
  12. Avatar
  13. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Humm, always thought the steering was a little light. Wheres the settings in Vagcom?
    Cheers :)
  14. Dandle
    Dandle Member
    852
    The information is in the second post above.
