Horn/wipers/indicators/full beam/dash lights not working
Immsey
Horn/wipers/indicators/full beam/dash lights not working?
Done loads of reading but can't find any posted solutions for my exact issue. I have changed and recoded a replacement steering control module but thats not sorted it. Some suggest ignition switch but a sympton I read would be radio staying on after removing key from ignition, but theres no problem with this. So nothing works from the stalks, nor the horn. The sidelights and headlights and foglights all work (as they don't turn on with stalks like the B5) but the dash backlight doesn't light up or the centre console, the climate panel and radio work. Desperate for anyone to point me in the right direction that have seen exact issue.
I see
1 Fault Found:
00457 - Control Module for Network (J519)
49-00 - No Communications
in VCDS...... heres complete scan.......:
Tuesday,10,January,2017,22:37:28:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ8E92A002647 License Plate: Y231KGX
Mileage: 69340km-43085mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E92A002647 Mileage: 69340km-43085miles
Address 01: Engine Labels: 06B-907-557-ALT.lbl
Part No: 8E0 909 557
Component: 2.0L R4/5VS 0001
Coding: 0011501
Shop #: WSC 63351 000 00000
VCID: 70EFBAA6606239C250-515E
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04275
Shop #: WSC 00060
VCID: 65C1DBF2FFA0EC6A33-515E
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0508
Coding: 00000
Shop #: WSC 63351
VCID: 5EB3F41EDAF6BFB2F2-5140
2 Faults Found:
Address 09: Cent. Elect. Labels:
VCID: 55A1EB32ACC07CEAA3-4B1A
Note: Excessive Comm Errors
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
VCID: 74E7B6B6147A05E2B4-5140
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0302
Coding: 00001
Shop #: WSC 63351
VCID: 36634CBE128657F24A-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D14
Coding: 00400
Shop #: WSC 00060
VCID: 2A5B68CED63E0312DE-5140
WAUZZZ8E92A002647 AUZ6Z0A0080385
1 Fault Found:
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0503
Coding: 00001
Shop #: WSC 00000
VCID: 6BD5ADCA1944DA1A65-5140
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AJ
Component: Komfortgerát T9F 0619
Coding: 06859
Shop #: WSC 00060
VCID: 79F987826318788AE7-4B00
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 4.11
8 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01332 - Door Control Module; Passenger Side (J387)
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 152
Component: chorus II GRO 0002
Coding: 00000
Shop #: WSC 63351
VCID: 5DB1F312D7F0A4AAEB-4B00
End-------------------------(Elapsed Time: 06:03)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
67 69 75 76 77
Coding: 0011501
Readiness: 0110 0101
Coding: 04275
Shop #: WSC 00060
VCID: 65C1DBF2FFA0EC6A33-5140
1 Fault Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
VCID: 55A1EB32ACC07CEAA3-4B00
Coding: 0010602
VCID: 74E7B6B6147A05E2B4-515E
pauldazzle
Sounds like you may have a CCM (Central Control Module) issue.
Check the carpets for damp on the passenger side, as the CCM is located under the carpet, & is prone to water ingress if the Plenum chamber drain plugs are blocked. CCM failure causes multiple electrical problems.
IIRC the steering angle code only clears after driving the car around a couple of corners after resetting.
Immsey
I'll have a look at that tomorrow, cheers
AudiMark3.0
Had the same issue a few years ago on my 3.0 QS Avant. No fault codes but issue got worse when car was warm. Dealer replaced ignition switch didn't fix problem. Needed new module under dash about £300 if I recall correctly
Immsey
Any chance of finding out exactly which module? Have replaced steering wheel control module and coded but not resolved
Immsey
So I have had all the carpet up today and located CCM module, but everything is bone dry and looks ok visually! Car is old Y reg but only done 43k miles! Should I replace CCM anyway do you think?
sumo
On board power supply control unit faulty, that's why you have lost wipers horn lights. Ccm doesn't control these.
AudiMark3.0
Sorry, this was 5-6 years ago and don't have part number.
The dealer repeated the issue by swapping module to another car.
Now switched to the darkside (BMW)
Immsey
Thank you so much.... found behind fuse panel, £20 from ebay, problem solved. Used VCDS to recode fro trailer hitch and learn VIN. Now to sell CCM module and steering control module which of course didn't fix issue! I hope others make use of this thread in the future. Cheers Sumo
