First post, joined in 2014 for some reason, probably thinking about an Audi then as well
So I think it’s an 8P, it’s a 2011 A3 S-Line 1.8TFSI..
Found out today that is has a timing chain so don’t need to be concerned about a belt needing changing.
Would possibly think about a remap at some point, so are the clutches in these cars pretty good at handling the extra 50hp or can they tend to slip. Car has done around 80k. I know it will be down to previous owners driving style, but is the clutch stronger in the 1.8 over the 1.4 and 1.2TFSI, and what is the ft/lb torque rating?
ICE - I would like to change the Audi Chorus double din unit for something that offer Apple CarPlay.
I’m quite handy with ICE in general, and I right in thinking there will be an amplifier for the rear 2 speakers which will need cutting out the equation and wired directly to head unit? I may just install an aftermarket amplifier at the same time for this.
But main question is around the compatibility and harnesses required to get a double din head unit installed, or use a facia etc. Ok with that bit, just the bit around connecting it to the Audi loom.
Oil - I’m quite aware these engines can use a lot of oil, I think I read somewhere about a good 5w-40 oil can slow this down, so thoughts around that also.
Will have a read around the forums also which may answer some of the above questions, but know things can be particular and different with each Audi model and engine.
Thanks in advance
Stu
Thanks in advance
Stu
