High beams not working b8.5
Audiforlife
Got my mot coming up soon and I need to get the high beams working. I've changed the stalk for a known working one as vcds shows a fault with the stalk and still nothing. The car had previously had light front end damage before I purchased it so I know the headlights have been changed so I'm hoping they are tbe correct ones!
My options list shows for headlights
8BP = Bi-functional headlight with gas discharge lamp
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
On the headlights there is the normal d3s bulb but also a h7, would this be for the full beam? I've changed the h7 bulbs for known working ones and still nothing. Not even the symbol on the dash
Pic of front of headlight needed.
You should have the led drl strip.
Yes. Best picture I have at the minute
Should be bixenon with led drl & the indicator is the halogen.
That's had an upgrade front end afaik, either wiring, coding or a module.
The H7 in there is the turning light. Put full lock on when it’s dark and they should illuminate. (LH lock = LH bulb)
Never seen that before. And no they don't
Wednesday,13,October,2021,17:16:52:27963
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WAUZZZ8K4DA071092 License Plate:
Mileage: 183110km-113779mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8K4DA071092 Mileage: 183110km-113779miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JG HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2839
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JG 003005
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 78AAE292A255987B4B2-802C
3 Faults Found:
5380 - Valve for Air Filter Bypass Flap (N275)
P1016 00 [047] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 182514 km
Date: 2021.09.30
Time: 21:18:14
Engine RPM: 830.50 /min
Normed load value: 20.8 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 29 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.620 V
Unlearning counter according OBD: 40
Air mass: specified value: 260.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 75.9 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside temperature: 19.0 °C
Coolant fan 2: activation: 0.00 %
Coolant fan 1: activation: 10.20 %
Fuel temperature: 25.5 °C
4481 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 182541 km
Date: 2021.10.01
Time: 13:46:24
Engine RPM: 1722.00 /min
Normed load value: 37.3 %
Vehicle speed: 95 km/h
Coolant temperature: 80 °C
Intake air temperature: 20 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.580 V
Unlearning counter according OBD: 36
Cruise Control System (CCS): switch position-Bits 0-7: 128
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 7
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 182541 km
Date: 2021.10.01
Time: 13:46:24
Engine RPM: 1721.00 /min
Normed load value: 44.7 %
Voltage terminal 30: 14.600 V
Cruise Control System (CCS): switch position-Bits 0-7: 192
Cruise Control System (CCS): status-Bits 0-7: 200
Cruise control switch-off: irreversible-Bits 0-7: 0
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Revision: -------- Serial number: --------------
Coding: 161544
Shop #: WSC 06334 000 00000
VCID: 005A8A72FA05D0BB732-8054
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 FE HW: 8K0 907 064 FE
Component: BCM2 2.0 H11 0602
Revision: 00002001
Coding: 03B20000000000000000
Shop #: WSC 06335 000 00000
VCID: 78AAE292A2D5987B4B2-802C
Subsystem 1 - Part No SW: 8J0 HW: 7P6 959 754 AJ
0051
Serial number: 0812000148383012
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000102435009
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AD HW: 8K2 820 043 AD
Component: KLIMA 3 ZONEN H04 0036
Revision: D1000000 Serial number: 01110520120620
Coding: 342402E000
VCID: 6B80CDDEE38323E3B60-803E
3 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 225
Mileage: 182508 km
Time Indication: 0
Date: 2021.09.30
Time: 20:49:25
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 225
Mileage: 182508 km
Time Indication: 0
Date: 2021.09.30
Time: 20:49:25
Freeze Frame:
Temperature: 18.0°C
01809 - Actuating Motor for Temperature Flap; Left (V158)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 14
Mileage: 182661 km
Time Indication: 0
Date: 2021.10.05
Time: 10:42:34
Freeze Frame:
Voltage: 14.50 V
Temperature: 18.0°C
Temperature: 14.0°C
Count: 10000
Count: 9768
Bin. Bits: 01000000
Bin. Bits: 00001111
Time: 255.00 s
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH
Component: BCM1 1.0 H14 0103
Revision: 08014001 Serial number: 00000031016902
Coding: 260000108034AFC00081400300001D0D001D070827090201000008000400020100000024000000
That's about 3 weeks old. I will do a fresh one tomorrow when I get my laptop back
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Mileage: 183400km-113959mi Repair Order:
VIN: WAUZZZ8K4DA071092 Mileage: 183400km-113959miles
Revision: 45H25--- CVN: 1CE921D9
VCID: 78AAE292A255987B9F1-802C
VINID: 9D196AAAA21B1144401C100908D658E9CE
1 Fault Found:
P1016 00 [039] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 183405 km
Date: 2021.11.08
Time: 19:59:12
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 70 °C
Intake air temperature: 16 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.860 V
Air mass: specified value: 740.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 40.3 °C
Outside temperature: 13.5 °C
Fuel temperature: 20.5 °C
Coding: 161544
VCID: 005A8A72FA05D0BBA71-8054
Revision: 00002001
VCID: 78AAE292A2D5987B9F1-802C
Component: FBSTOUAREGIDG H05 0051
Coding: 342402E000
VCID: 6B80CDDEE38323E3623-803E
3 Faults Found:
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Temperature: 13.0°C
Shop #: WSC 14401 000 1048576
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 080512 H06 0070
Serial number: SWF12050085281
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20279253
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000205120952
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: DD18CB26000000000001
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:11
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD930EXO
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 57049 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 48CA5252923528FB2F1-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME467B230FL
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME6B72196CS
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME3B15576ET
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME02160A5AC
Crash sensor for front airbag: driver side:
Serial number: 63732SME0A3F447CB
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME043F1A54%
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120521000160
Coding: 000017
VCID: 4FF8794E77DBFFC36EB-801A
Component: E221 - MFL H03 0004
1 Fault Found:
00886 - Turn Signal Switch (E2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 B HW: 8K0 920 982 B
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTE50RJ5D
Coding: 332D100002012600010000
Shop #: WSC 06335 123 12345
VCID: 333015BEFB33BB236A3-8066
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y12506000F
Coding: 00CF07FF00
VCID: 3FD8498EC77B6F439EB-806A
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 4959957401
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12129001355011200410
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C02205E21410001
Shop #: WSC 06325 000 00000
VCID: 56F68C2A48018E0BADD-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0021528868
Coding: 100000000001
Shop #: WSC 00185 210 106624
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 343216A2FEBDBC1B739-8060
1 Fault Found:
18689 - Terminal 30
U140A 00 [008] - Open Circuit
[Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 183405 km
Date: 2021.11.08
Time: 20:10:29
Write only channel
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0176764536
Coding: 013B062220B900408020023680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H04 0030
Revision: 00004001 Serial number: 94814003338701
VCID: 2D0403C61D17EDD33C7-8078
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 Q HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000030942627
Coding: 011002204001410001
VCID: 4DC463467DD7CDD31C7-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 00000000053132
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 36362CAAE8C1AE0B4DD-8062
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109E20C7563849
Coding: 010103010000000001
VCID: 1F18E90E67BB0F43BEB-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 C HW: 8R2 035 666 C
Component: H-BN-EU H44 0524
Revision: -------- Serial number: 206DO0C7500525
Coding: 0F010101000681ED01808F5E00000403E40000020000000000
VCID: 392C2796D95F4173A0F-806C
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130E/0CS170250
Subsystem 3 - Part No SW: 8T0 919 611 B HW: 8T0 919 611 B
Component: E0380 Bedient H02 0020
Serial number: 00000001158202
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
3 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:13
Freeze Frame:
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:21
Freeze Frame:
Voltage: 11.80 V
03278 - Functionality Limited due to Missing Messages
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:16
Freeze Frame:
Bin. Bits: 00001000 00000000
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000030304399
Coding: 010002204001210001
VCID: 43D0457EAB930BA3FA3-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000030307586
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.0V)-----------VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 183405 km
Date: 2021.11.08
Time: 19:59:12
Coding: 161544
Revision: 00002001
Coding: 342402E000
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Freeze Frame:
Temperature: 13.0°C
Coding: 00FD11
Coding: 02005D
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:11
Coding: 000017
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:09
Coding: 00CF07FF00
1 Fault Found:
18689 - Terminal 30
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 183405 km
Date: 2021.11.08
Time: 20:10:29
Write only channel
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:13
Freeze Frame:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:21
Freeze Frame:
Voltage: 11.80 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 183405 km
Time Indication: 0
Date: 2021.11.08
Time: 19:59:16
Freeze Frame:
I don't know if its connected to your problem but those scans showed the battery voltage drop from 12.3V to 12.0V in less than 2 minutes, there are electrical DTCs and 11.8V recorded at one point.
Reactions: Audiforlife
The previous owner fitted a cheap 70ah battery. First noticed after the battery went flat on me after sitting in the car with the radio on for 10 minutes. It's been fine for the last year never failed to start just have to remember about it lol
One of your previous scans showed energy management active. What did you do to resolve that?
Edit: energy management can cause very strange/erratic errors to be logged and send you on a wild goose chase
I didn't do anything apart from clear the fault codes in each module
If the battery goes flat after 10 minutes and you have experienced energy management warnings I would resolve that first with a battery check/new battery to rule that out before you continue your diagnosis. I had similar random errors due to a failing battery earlier this year. New battery and the problems were solved.
