  2. Dismiss Notice
Help with VCDS coding issue please
mechanic69 Mar 5, 2017
  1. mechanic69
    mechanic69 Registered User Gold Supporter VCDS Map User
    2,066
    784
    So I have installed a german climate controller in my S3 8P so the unit is coded to left hand drive.
    In 08 HVAC module the unit coding is shown as
    So I want to change 01000 to 10100 but the unit has the coding button shaded out!
    The label states the following:
    Can anyone help with where to run "basic setting (MVB 001)"
  2. Avatar
    snack-media
    Advertisement
  3. Oswald
    Oswald Active Member VCDS Map User
    125
    34
    [04] basic settings -> channel 1
  4. mechanic69
    2,066
    784
    So that's module 04? Thanks I'll give it a go
  5. Oswald
    125
    34
    No no, go to 08 hvac then select section 04 basic settings, channel 1, click go and it will adapt
    mechanic69 likes this.
  6. mechanic69
    2,066
    784
    OK, I wasn't sure cos it looked like that only cycled the flap motors
  7. Oswald
    125
    34
    That label file you posted says it would get all info from other controllers during basic settings. It can be one of the adaptation channels as well, but the only problem is these are not described.
  8. mechanic69
    2,066
    784
    Spot on, worked a treat, cheers Oswald
    I am getting fault code 00457 (had it before adaptation as well) it won't clear any ideas??
  9. mechanic69
    2,066
    784
    My thanks go out to Oswald and people like you who help solve our problems. I love it when a problem is sorted
    Oswald likes this.
  10. tcardio
    tcardio Registered User
    1,456
    548
    mine does the same and no problems with the function. I just ignore it
  11. Oswald
    125
    34
    Check for errors in 09 and 17
  12. Avatar
    snack-media
    Advertisement
  13. mechanic69
    2,066
    784
    Same as no probs with function just like sorting these things out
  14. mechanic69
    2,066
    784
    Module 9 & 17? I've cleared all fault codes in other modules but his one still there
  15. downtothebone
    downtothebone Registered User
    832
    200
    43
    If this is the Q3 unit then I believe you will always get a fault - mine does the same. I hadn't worked out the LHD to RHD coding so I'll try this out ...
  16. mechanic69
    2,066
    784
    Yeah Q3 unit, works fine just nice to sort these things out
  17. Oswald
    125
    34
    I reckon you need a q3 gateway to sort it.
  18. mechanic69
    2,066
    784
  19. mechanic69
    2,066
    784
    Seen the unit is behind the glovebox on the A3 but am worried this will effect other things, like this "Once you fit the new gateway the car will go into component protection and a good few things won’t work, like climate control and instrument cluster (Speedo will work). Component protection can only be removed by a dealer or a company with a license VAS unit connected to Audi's database in Germany."
    Sounds like just more pain for no gain?
  20. Oswald
    125
    34
    Yes, thats the module. Theres no CP on gateway modules:) You just need to recode replacement accordingly to your old one.
  21. mechanic69
    2,066
    784
    So I checked my module behind the glovebox, I think this is it?
    And the CAN on VCDS states
    Also it has one connection
    The Q3 module has two
    But it also states + BEM on the module
    Am I right in thinking the second connection is for Battery Energy Management and I don't need it?
    I am assuming it would work OK with just one cable connected?
  22. mechanic69
    2,066
    784
    Is this a software issue in the module itself, couldn't I just get a later 8P module with a similar date of the heater controller?
  23. Oswald
    125
    34
    I would say it would work with one plug connected. Just get the coding of module 19 not 09. 09 is the board under steering wheel with relays.
  24. mechanic69
    2,066
    784
    yeah got the coding from 19
    Oswald likes this.
  25. mechanic69
    2,066
    784
    Got the module today and swapped it over. Fitted ok. Couldn't match coding. The long coding was one byte less than original, also the installation list was missing about 5 other modules fitted to my car!! Must be a mid range module not highline. VCDS also said it might need special equipment to code.
    Back tot the drawing board.
