Help with part No 4F0907289K
AndyS-line
Hi Guys
I have a fault with my a6 c6 avant 2010rear right lights not working and have had it checked and been told its a faulty module part no 4F0907289K. Trying to find a 2nd hand replacement and can find them ending in every other letter. The question is will these be just a straight swap over or need coding or must it be the same ? .
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01236052000000
Coding: 3277563
Shop #: WSC 02335 785 00200
VCID: 326C9672AD50C6DF61-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
4 Faults Found:
01519 - Bulb for Back-Up Lights; Right (M17)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 44
Reset counter: 197
Mileage: 304125 km
Time Indication: 0
Date: 2019.10.29
Time: 06:47:59
02935 - Control Circuit for Tail-Light; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 95
Reset counter: 199
Mileage: 304125 km
Time Indication: 0
Date: 2019.10.29
Time: 06:48:28
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 159
Mileage: 277745 km
Time Indication: 0
Date: 2018.10.11
Time: 18:50:44
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 149
Mileage: 306143 km
Time Indication: 0
Date: 2019.11.24
Time: 12:45:27
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Unfortunately this will not be a straight swap. You will need to find a professional in order to perform the change over as coding and security works are needed. If you are located near, or can get to, North London I can complete the works for you.
AndyS-line
I am in Glasgow i am afraid. I have managed to source one with the same part number will this still have to be coded and security done ?.
