AK47UK
- Joined
- Sep 26, 2013
- Messages
- 447
- Reaction score
- 35
Hoping someone can help me out with this please. Points to note, the battery has drained recently to a point that the central locking wouldn't work, I think this is because the power magic pro hasn't been shutting the dash cam power off. The battery only drains to the point the car will not start when it has not been used for 48-72 hours. I am fairly sure the drain is the dash cam as I disconnected the cam over the weekend and the car started fine on Monday. Other than that a couple of fuses were removed whilst the ignition was off to piggy back off of them, this was for blowers and cigar lighter.
I just checked the dipstick and it is up to the maximum level.
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH15--- Serial number: AUX7Z0J1FN40UC
Coding: 0143000C18070060
Shop #: WSC 66565 257 00032
VCID: 41832EF1186C67106E2
1 Fault Found:
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 59280 km
Time Indication: 0
Date: 2014.06.10
Time: 10:20:33
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 51.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
Readiness: 1110 0101
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000391 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78F583150B36E6D819C
2 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 59162 km
Time Indication: 0
Freeze Frame:
Temperature: 14.0°C
Voltage: 12.80 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 59266 km
Time Indication: 0
Date: 2014.06.10
Time: 09:01:15
Freeze Frame:
Temperature: 19.0°C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 M HW: 8P0 920 982 M
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005007985
Coding: 0004428
Shop #: WSC 00359 210 17515
VCID: 438F24F9027075007CE
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 59280 km
Time Indication: 0
Date: 2014.06.10
Time: 10:21:44
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 59280 km
Time Indication: 0
Date: 2014.06.10
Time: 10:20:33
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 51.0°C
Voltage: 12.065 V
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 59162 km
Time Indication: 0
Freeze Frame:
Temperature: 14.0°C
Voltage: 12.80 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 59266 km
Time Indication: 0
Date: 2014.06.10
Time: 09:01:15
Freeze Frame:
Temperature: 19.0°C
Coding: 0004428
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 59280 km
Time Indication: 0
Date: 2014.06.10
Time: 10:21:44
