Help with fault codes please
Michaelhare
Member
Hi all I was driving on a motor way the other day when I lost power my epc and traction control light came on pulled over turn car off and back on which reset it and was all ok again but now have these codes when I ran vcds any help would be great many thanks Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B
Component: 1.8L R4/5VT 0010
Coding: 0011711
Shop #: WSC 06335 000 00000
VCID: 7F0AA46E2D9087C607-515A
1 Fault Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004871
VCID: 275A5C0E9680EF061F-8072
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x7600
Hex Value: 0x4006
Hex Value: 0x00FF
Hex Value: 0xFFB1
Hex Value: 0x00FF
SAiLO
Well-Known Member
Your accelerator pedal is playing up, could be the connection. You could try unplugging it cleaning the pins and plugging back in.
Michaelhare
Member
Somone said about OXS oxygen sensor heaters are just starting to short........ fuse them or replace them............before they wipe out the control unit.
