Hi all
Audi A4 2.0 TDI 143 BHP
For a while I have noticed that the throttle on my car is a little jerky and hesitant, I also noticed a bit of a shudder when turning off the engine. Engine management light came on today so I have given it a scan...
I know there are quite a few faults there, but looking to get the fault with the engine module sorted as a priority. Given that the car has almost done 100k I'm guessing that the throttle valve actuator is well and truly gunked up and will need a good clean. Does anyone know what parts (gaskets etc) I will need to do this job? Hoping to get them in for the weekend so I can give it a go.
Many thanks in anticipation.
Code:
Monday,06,July,2015,17:50:51:16310
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WAUZZZ8K99A150118 License Plate:
Mileage: 156250km-97089mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K99A150118 Mileage: 156250km-97089miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGC) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3177
Revision: 11H01---
Coding: 0104002C18072118
Shop #: WSC 06325 123 12345
ASAM Dataset: EV_ECM20TDI03L906022 A01005
ROD: EV_ECM20TDI03L906022.rod
VCID: 62CBE2D77570073118B-8037
1 Fault Found:
5293 - Throttle Valve Actuator Module (J338): Motor Circuit
P2103 00 [168] - Signal High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 29
Mileage: 156236 km
Date: 2015.07.06
Time: 07:40:02
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AC HW: 8K0 907 379 AC
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 160D00
Shop #: WSC 06325 000 00000
VCID: 7AFBBAB7F5E0EFF120B-802F
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 201
Mileage: 155677 km
Time Indication: 0
Date: 2015.06.27
Time: 11:17:53
Freeze Frame:
Hex Value: 0x4C00
Hex Value: 0x4006
Hex Value: 0x121A
Hex Value: 0x0EB5
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0143
Revision: 00002001
Coding: 031100
VCID: 306F589F631CE5A1DEF-8065
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0125.09.080050
Coding: 34040000
VCID: 428B0257DDB0673138B-8017
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 A HW: 8K0 907 063 A
Component: BCM1 1.0 H22 0253
Revision: 02022001 Serial number: 00000000223153
Coding: 690040B10034A7000001000000005F5F0F1D020800000141000000
VCID: 2D5141EB742E8849F59-8078
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290908 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52830827105457
Coding: 100003
VCID: 3B757FB3BA5A16F97BD-806E
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1BHDUT
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C777CAFB75411C1727-8069
Crash sensor for side airbag; driver side:
Serial number: 6334MSME431414640
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME41426B024
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME0D100F129
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME40103E000
Crash sensor for front airbag; driver side:
Serial number: 63732SME2B10511EY
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME2F0B2D224
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HJ60006G
Coding: 000016
VCID: 3D7171ABA44E18C9459-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H17 0224
Revision: 00100000 Serial number: 9E367W3A8
Coding: 2F05080003002600010000
VCID: 31695D9B6816ECA9D11-8064
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G089248471
Coding: 000303
VCID: 46831E47F1985B11143-8013
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020202
VCID: 78FFA0BFCBECFDE156F-802D
1 Fault Found:
03272 - Control Module for Audio Interface
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 50
Reset counter: 225
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007806956
Coding: 011C02205001410001
VCID: 3F8D0BA3AE420AD9575-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0115073713
Coding: 011B0622003904C0002001
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 155444 km
Time Indication: 0
Date: 2015.06.23
Time: 18:23:50
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0103010102
VCID: 6ED386E7B9A8B3518C3-803B
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007879689
VCID: 3E7376A7A94803D15C3-806B
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 17
Reset counter: 182
Mileage: 155444 km
Time Indication: 0
Date: 2015.06.23
Time: 21:45:42
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000112117
Shop #: WSC 00000 000 00000
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 195 H HW: 8T2 035 195 H
Component: Symphony3 H02 0210
Revision: 00000004 Serial number: AUZ5Z4H1041898
Coding: 0402008201018D00435B870900
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 200
Mileage: 155534 km
Time Indication: 0
Date: 2015.06.26
Time: 12:02:57
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000007815483
Coding: 010C02204001210001
VCID: 408F085FD3BC75212EF-8015
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007912705
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H42 0660
Revision: 00000000 Serial number: 00000005257414
Coding: 0010320
Shop #: WSC 06443 128 28888
VCID: 3D7171AB644E18C9459-8068
End-------------------------(Elapsed Time: 03:03)--------------------------
