Help with coding
AndyS-line
Hi Guys just bought a A5 B9 2017 and would like to some tweaks if poss. I have a Hex V2 cable and AutoScanned
With the following return See below.The Tweaks i would like are if poss. i just dont want to go changing codes before knowing its the correct ones to verify first .
Any help would be smashing.
Andy
Code:
VIN: WAUZZZF55HA023829  License Plate: YR17 XHT HV2
Mileage: 143267km-89021mi  Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D A5 AC BB
  BC D6 D7
VIN: WAUZZZF55HA023829  Mileage: 143267km-89021miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DETA)  Labels: None
  Part No SW: 04L 906 026 GC  HW: 04L 907 309 L
  Component: R4 2.0l TDI  H35 3397
  Revision: B1H35---
  Coding: 0A194032232415087408
  Shop #: WSC 06314 790 00001
  ASAM Dataset: EV_ECM20TDI01104L906026GC 004004
  ROD: EV_ECM20TDI01104L906026GC_004.rod
  VCID: 71BFD197A123FFF3ADD-8024
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)  Labels: 8W0-907-379-PLU-V1.clb
  Part No SW: 8W0 907 379 G  HW: 8W0 907 379 J
  Component: ESP9 Plus  H06 0719
  Coding: 0CAA489A08A40A9911A6489300865292E6C196301210508812004A49678369
  Shop #: WSC 06334 790 00001
  ASAM Dataset: EV_ESP9BOSCHCMP 001001
  ROD: EV_ESP9BOSCHCMP_001.rod
  VCID: 49CF5977E933E733C5D-801C
Address 08: Auto HVAC (E87)  Labels:* Redir Fail!
  Part No SW: 8W0 820 043 G  HW: 8W0 820 043 G
  Component: Klima Zone 3  H32 0071
  Coding: 141800295544440D02000100880000000000000000000000000000000000
  Shop #: WSC 06335 790 00001
  ASAM Dataset: EV_AirCondiBHTCAU491 001013
  ROD: EV_AirCondiBHTCAU491.rod
  VCID: 372B2F8F8FC761C3A39-8062
  Fresh Air Blower Front:
  Subsystem 1 - Part No SW: 4M1 820 021 A  HW: 4M1 820 021 A
  Component: J216 FLuftV  H08 0003
  Serial number: 00000000000001317619
  Relative humidity sensor in fresh air intake duct:
  Subsystem 2 - Part No SW: 4H0 907 658 A  HW: 4H0 907 658 A
  Component: AQ_Hum_Sensor  H01 0006
  Serial number: 79890C8880PAG0MUFU02
  Rear Climatronic Operating And Display Unit:
  Subsystem 3 - Part No SW: 8W0 919 158  HW: 8W0 919 158
  Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)  Labels:* None
  Part No SW: 8W0 907 063 CG  HW: 8W0 907 063 BG
  Component: BCM1 MLBevo  H13 0267
  Coding: 07501143E11800CD054587141B8C80B9110B3108000000000000000020001A810A450122025601
  ASAM Dataset: EV_BCM1BOSCHAU736 018006
  ROD: EV_BCM1BOSCHAU736_018_AU49.rod
  VCID: 025D8E5B9485F46B447-8056
  Control Unit For Wiper Motor:
  Subsystem 1 - Part No SW: 8W6 955 119 A  HW: 8W6 955 119 A
  Component: 494 RL 170117  036 0471
  Serial number: 00000001701160400446
  Coding: 5FC7F7
  Rain Light Recognition Sensor:
  Subsystem 2 - Part No SW: 81A 955 555 A  HW: 81A 955 555
  Component: G397_RLFSS  H06 0002
  Serial number: 20260180X81A955555A0
  Coding: 02005D
  Light switch:
  Subsystem 3 - Part No SW: 4M0 941 531 AA  HW: 4M0 941 531 AA
  Component: E1 - LDS  H06 0008
  Serial number: 08 07 2016  00649974
  Automatic Day Night Interior Mirror:
  Subsystem 4 - Part No SW: 8W0 857 511  HW: 8W0 857 511
  Component: Y7_Innenspieg  H09 0002
  Serial number: GX1CE109111611910809
  Coding: 210000
  Interior Light Module:
  Subsystem 5 - Part No SW: 8W0 947 135 BQ  HW: 8W0 947 135
  Component: J528-Dachele  H14 0130
  Serial number: B00265208
  Convenience And Driver Assist Operating Unit:
  Subsystem 6 - Part No SW: 8W0 925 301 BC  HW: 8W0 925 301 BC
  Component: SL-B9/Q5NF  H17 0010
  Serial number: 2616000173118002
  Coding: 000000
Address 15: Airbags (J234)  Labels:| 8W0-959-655.clb
  Part No SW: 8W0 959 655 F  HW: 8W0 959 655 F
  Component: Airbag10.44  H03 0103
  Serial number: 003UP002CD76
  Coding: AACCF0C00C800000585400F3D0CC00000000
  ASAM Dataset: EV_AirbaAU10BPAAU736 005013
  ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
  VCID: 4CC16063E641F21BFEB-8018
  Side Sensor Driver Front:
  Subsystem 1 - Part No SW: -----------  HW: 442 062 901 17
  Component: SideSensor_Df  1E2 0887
  Serial number: 3577Y00AB206696131E$
  Coding: 2D2D2D
  Side Sensor Passenger Front:
  Subsystem 2 - Part No SW: -----------  HW: 442 062 501 17
  Component: SideSensor_Pf  1E2 0887
  Serial number: 3587Y00AD20669627481
  Coding: 2D2D2D
  Side Sensor Driver Rear:
  Subsystem 3 - Part No SW: -----------  HW: 442 0B0 902 17
  Component: SideSensor_Dr  1C7 0148
  Serial number: 3517700242A52B36481
  Coding: 2D2D2D
  Side Sensor Passenger Rear:
  Subsystem 4 - Part No SW: -----------  HW: 442 0B1 002 17
  Component: SideSensor_Pr  1C7 0148
  Serial number: 3527700242A52B36F5CF
  Coding: 2D2D2D
  Front Sensor Driver:
  Subsystem 5 - Part No SW: -----------  HW: 442 0C1 202 17
  Component: FrontSensor_D  1C5 014A
  Serial number: 35575002029DD0B7A83H
  Coding: 2D2D2D
  Front Sensor Passenger:
  Subsystem 6 - Part No SW: -----------  HW: 442 0C1 202 17
  Component: FrontSensor_P  1C5 014A
  Serial number: 35675002029DD0B7386E
  Coding: 2D2D2D
  Pedestrian Protection Center:
  Subsystem 7 - Part No SW: -----------  HW: 442 0C1 702 17
  Component: PedP_Sensor_C  1C5 014A
  Serial number: 23075000C2A4CE2A96DP
  Coding: 2D2D2D
  Pedestrian Protection Driver 2:
  Subsystem 8 - Part No SW: -----------  HW: 442 431 002 17
  Component: PedPSensor_D2  256 0887
  Serial number: I0M9M00A921781B45336
  Coding: 2D2D2D
  Pedestrian Protection Passenger 2:
  Subsystem 9 - Part No SW: -----------  HW: 442 431 002 17
  Component: PedPSensor_P2  256 0887
  Serial number: I0N9M00BB20DD062821C
  Coding: 2D2D2D
Address 16: Steering wheel (J527)  Labels: 4M0-907-129.clb
  Part No SW: 4M0 907 129 HA  HW: 4M0 907 129 HA
  Component: Lenks.Modul  H11 0009
  ASAM Dataset: EV_SMLSKLOAU736 006008
  ROD: EV_SMLSKLOAU736_006.rod
  VCID: 76B5E28BC84DD8CB78F-8022
Address 17: Instruments (J285)  Labels:* None-SRI2
  Part No SW: 8W6 920 971  HW: 8W6 920 971
  Component: TDIeGB  H08 0523
  Coding: 24A44496288006000120E9601000000000000000
  ASAM Dataset: EV_DashBoardAU736 001022
  ROD: EV_DashBoardAU736_AU49.rod
  VCID: 015F81579183EF735DD-8054
1 Fault Found:
16777024 - No Communication with Diagnostic Gateway
  U0146 00 [008] - -
  [BCME_0x23 communication error bap_error_timeout heartbeat]
  Intermittent - Confirmed - Tested Since Memory Clear
  Freeze Frame:
  Fault Status: 00000001
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 167
  Mileage: 143267 km
  Date: 2020.11.03
  Time: 19:55:33
Address 19: CAN Gateway (J533)  Labels:* None
  Part No SW: 8W5 907 468 D  HW: 8W5 907 468 C
  Component: Gateway  H30 0308
  Revision: 5A010004  Serial number: 0485A060817215
  Coding: 0301000100008640410700000059001248080007000000000175078E10000000
  ASAM Dataset: EV_CGateCONTIAU491 002040
  ROD: EV_CGateCONTIAU491_002_AU49.rod
  VCID: 4ACD667BEC35EC2BCC7-801E
  Multi Function Steering Wheel Control Module:
  Subsystem 1 - Part No SW: 8W0 951 523 E  HW: 8W0 951 523 E
  Component: J453 MFL  H04 0002
  Serial number: 20170113013945 20069
  Battery Monitoring Control Module:
  Subsystem 2 - Part No SW: 8S0 915 181 C  HW: 8S0 915 181 C
  Component: J367-BDMHella  H10 9070
  Serial number: 8968982504
Address 29: Left Light (J1018)  Labels: 4M0-907-397.clb
  Part No SW: 4M0 907 397 AB  HW: 4M0 907 397 B
  Component: LCM_MLBevoH05 0024
  ASAM Dataset: EV_LCMLeftHELLAAU736 001012
  ROD: EV_LCMLeftHELLAAU736_VW48.rod
  VCID: 77ABEF8FCF47A1C3639-8022
Address 2B: Steer. Col. Lock (J764)  Labels:* 5Q0-905-861.clb
  Part No SW: 3Q0 905 861 A  HW: 3Q0 905 861 A
  Component: ELV-MLBevo  H05 0032
  Serial number: 17000035131014
  Coding: 0000000000000000
  Shop #: WSC 00000 000 00000
  ASAM Dataset: EV_ELVMarquMQBB 001007
  ROD: EV_ELVMarquMQBB.rod
  VCID: 323D1E9B64A584EB947-8066
Address 39: Right Light (J1023)  Labels: 4M0-907-397.clb
  ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 42: Door Elect, Driver (J386)  Labels:* None
  Part No SW: 8W0 959 593 E  HW: 8W0 959 593
  Component: TSG FS  005 0057
  Serial number: 0000242178475
  Coding: 001FCA624001000000001482
  ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
  ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
Address 44: Steering Assist (J500)  Labels:* None
  Part No SW: 8W0 909 144 G  HW: 8W0 909 144 B
  Component: EPS_MLBEVO_ZF H08 0409
  Coding: 09000380008000
  ASAM Dataset: EV_EPSZFAU49X 003018
  ROD: EV_EPSZFAU49X_003.rod
  VCID: 41DF4157D1032F731DD-8014
Address 46: Central Conv. (J393)  Labels:* None
  Part No SW: 8W0 907 064 CB  HW: 8W0 907 064 B
  Component: BCM2 MLBevo  018 0344
  Coding: 012D00002F9100406301A0000600080231020010004306500F04000000040030001F0001000000
  ASAM Dataset: EV_BCM2HellaAU736 012013
  ROD: EV_BCM2HellaAU736_012_AU49.rod
  VCID: 7EA5FAABE07D908B20F-802A
  Sensor For Anti Theft Alarm System:
  Subsystem 1 - Part No SW: 5Q0 951 177  HW: 5Q0 951 172
  Component: Sensor, DWA  005 0316
  Serial number: 000000000ZY170161Q96
  Alarm horn:
  Subsystem 2 - Part No SW: 5Q0 951 605 A  HW: 5Q0 951 605 A
  Component: Sirene, DWA  005 0314
  Serial number: 00000000000068591789
Address 52: Door Elect, Pass. (J387)  Labels:* None
  Part No SW: 8W0 959 592 E  HW: 8W0 959 592
  Component: TSG BFS  005 0057
  Serial number: 0000241899479
  Coding: 001FCA224001000000001480
  ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
  ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
  VCID: 4BC3637FE34FF523F71-801E
Address 5F: Information Electr. (J794)  Labels:* None
  Part No SW: 8W0 035 192 G  HW: 8W0 035 192 A
  Component: MU-HS-LND-EU  045 0191
  Serial number:
  Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
  ASAM Dataset: EV_MUHigScl6C3DELP 001011
  ROD: EV_MUHigScl6C3DELP.rod
  VCID: 3A2D36BBBCD57CAB5C7-806E
  Data medium:
  Subsystem 1 - Part No SW: 8W0 919 866 M  HW: -----------
  Component: ECE 2017  --- 0024
  Serial number: --------------------
  Display unit 1 for multimedia system:
  Subsystem 2 - Part No SW: 8W2 919 604  HW: 8W2 919 604
  Component: AU49x_DU_STD  H40 0008
  Serial number: AUZ8Z9GBH00SK0
  Multimedia Operating Unit:
  Subsystem 3 - Part No SW: 8W0 919 614 J  HW: 8W0 919 614 J
  Component: ControlUnit_B  H21 0134
  Serial number: APVAK109011700040443
Address 6D: Trunk Elect. (J605)  Labels:| 5Q0-959-107.clb
  Part No SW: 8W8 959 107 B  HW: 8W8 959 107
  Component: HDSG-Modul  H13 0161
  Revision: --------  Serial number: 31198742200000
  Coding: 0610
  ASAM Dataset: EV_DeckLidCONTIAU736 001014
  ROD: EV_DeckLidCONTIAU736_VW37.rod
  VCID: 48C95C73F2391E3BDA3-801C
Address A5: Frt Sens. Drv. Assist (R242)  Labels:* Redir Fail!
  Part No SW: 8W6 907 217  HW: 8W6 907 217
  Component: BVS  H14 0042
  Coding: 0404090300000403024023A0A40000FC00F0C020C000
  ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
  ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
  VCID: 7F5B07AFE77799832B9-802A
1 Fault Found:
1123600 - predictive route data
  B1630 02 [008] - Signal Failure
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 2
  Reset counter: 167
  Mileage: 143253 km
  Date: 2020.11.02
  Time: 13:26:59
  Control Module temperature: 19 °C
  Voltage terminal 15: 14.80 V
Address AC: Reductant Control (J880)  Labels: 4M0-907-355.clb
  Part No SW: 4M0 907 355 D  HW: 4M0 907 355 B
  Component: SCR-Stg-G3H05 0006
  ASAM Dataset: EV_RDCMINERGAU736 005012
  ROD: EV_RDCMINERGAU736_AU49.rod
Address BB: Door Rear Drv (J388)  Labels:* None
  Part No SW: 8W0 959 595 E  HW: 8W0 959 595
  Component: TSG HFS  005 0057
  Serial number: 0000242196328
  Coding: 000FC8220001000000001080
  ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
  ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
  VCID: 4EC56A6B105DC00B90F-801A
Address BC: Door Rear Pass (J389)  Labels:* None
  Component: TSG HBFS  005 0057
  Serial number: 0000242196218
  ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
  ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address D6: Light Ctrl Left 2 (A31)  Labels: 7PP-941-572.clb
  Part No SW: 7PP 941 572 AC  HW: 7PP 941 572 A
  Component: LED1L  H09 0008
  ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
  ROD: EV_LEDModLeftMELCOAU736_AU37.rod
  VCID: 176BCF0FEF0741C3839-8042
Address D7: Light Ctrl Right 2 (A27)  Labels: 7PP-941-572.clb
  Component: LED1R  H09 0008
  ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 01:42, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
[CODE]
