- Joined
- Nov 4, 2006
- Messages
- 2,628
- Reaction score
- 79
VIN: WAUZZZ8X4BB043750 License Plate:
Chassis Type: 8X-AU21 (8X0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X4BB043750 Mileage: 150310km-93398miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
4106 - Bank 1; System too Rich at Idle
P2188 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 12
Mileage: 148380 km
Date: 2022.03.21
Time: 11:30:14
Engine RPM: 896.50 /min
Normed load value: 39.2 %
Vehicle speed: 0 km/h
Coolant temperature: 88 °C
Intake air temperature: 39 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.371 V
Unlearning counter according OBD: 40
Long-term fuel trim bank 1 at idle: -6.98 %
Oxygen control: adaptation value at partial load: bank 1: 0.97855
Tank venting adaptation factor: 6.275
Height correction: 0.98132
Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.: 0.6665
Oxy sensor 1 bank 1 char curve offset: -0.00308
Oxygen sensor test: bank 1: delta lambda: 0.00000
Any ideas.... Before I change the pre cat 02 sensor?
P2188 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 148380 km
Date: 2022.03.21
Time: 11:30:14
