Help! Water in rear driver side footwell!
Benjammin69 Aug 9, 2017
  1. Benjammin69
    Benjammin69 New Member
    Hi all hope you can help me! I have Audi 2.4 v6 cab 54 plate, and I went away on holiday a few weeks back got back got in the car and there was water in the front and rear drivers side footwell. There's no leakage roof and the water is about an inch or 2! I really am stuck in how the waters getting there! I've sat in the car in the rain looking for leaks can't find anything! Help!
  2. Avatar
    Google AdSense Advertisement
  3. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,905
    686
    Either the seal under the Ecu housing or the bonnet release cable, these are well known for allowing water ingress.
  4. DGSdale
    DGSdale Member
    94
    Did you ever find the source of your leak and cure it?
  5. V.U.
    V.U. New Member
    It happened to me a few times too. In my case rain water was coming from the engine compartment. It was collected under the battery and entered the cabin through the cabin air filter.
    The solution is to take out the battery and clean the drain hole located under it.
  6. p-rossi
    p-rossi New Member
    13
    I took the rubber seal out from below the battery as it had been cleaned before but clogged up a second time & it got both footwells flooded. I thought I was over all of that, only to find that the seal on the lower ECU chamber has split & letting water in - only the driver's side has flooded.
    Have you stopped the water coming in now?
  7. p-rossi
    p-rossi New Member
    13
    I'm just off the phone to Audi in Inverness & you can't buy the seal for the ECU lower chamber on its own (doesn't have its own part number) - you need to purchase the ECU lower chamber & the seal comes with it. I was quoted £41 inc VAT.
