Help! Repair nightmare.
Tom Shields
Member
I'm having a nightmare with repairs to my car.
Let's start the story:
In February my turbocharger wastegate solenoid developed a fault which caused the car to go into limp home mode. I diagnosed the fault, with VCDS, and ordered a replacement part on this site and had it fitted by a local garage with access to ODIS, they even checked the wiring from the ECU to the actuator for free to ensure that the actuator was the problem.
Fast forward to 3 weeks ago. EPC light and limp home mode. I diagnosed the actuator again with VCDS. So I booked it in with my local Audi for them to replace it under warranty. They discover that the wiring has been damaged in the ECU and actuator plugs.
Need advice on what I can do. I'm out of pocket £218.40 to Audi for them diagnosing it and can't afford any more for what seems like someone else's mistake.
Please help.
Sorry for the essay.
hopgop1
First port of call would be to speak to your local garage I think, see what they have on file about the fitment of the part. Then tell them about what has happened now, maybe the ECU check was free because they broke something! To be honest though I doubt they'll own up to it if it was them who caused it, even if you had evidence it was them you'd almost certainly have to go to small claims court which is more trouble than it's worth. You're in quite a tricky situation there.
AndyKnight
Why did you pay for it to be fixed the first time and then go warranty route the second?
RichardT
I assume he means warranty on the faulty part. But I wouldn’t think it likely that a dealer would be interested in that unless the part was fitted by an Audi dealer. And it looks like his experience matches that.
Unfortunately it looks like he should have gone to a dealer in the first place.
Tom Shields
Member
You are correct. However it doesn't matter who fitted the part, it would still be under warranty. This was confirmed by the dealer.
The car is 5 years old so going to the dealer initially would have made the job a lot more expensive initially. I had diagnosed the fault myself and didn't need Audi to fit it to get the warranty on the part.
