help please
nick1973
got car running but now have these faults have changed passenger, driver airbags driver , passenger belt tensoners and drivers side rear tensioner any ideas
air con not piped up yet
not bothered about speaker
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00044
Shop #: WSC 06435
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
Address 15 -------------------------------------------------------
Controller: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 01104
Shop #: WSC 06435
5 Faults Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High - Intermittent
00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
01211 - Belt Tensioner Igniter: Rear Driver Side (N196)
36-10 - Open Circuit - Intermittent
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
30-10 - Open or Short to B+ - Intermittent
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 17 -------------------------------------------------------
Controller: 8L0 920 980 N
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 04440
Shop #: WSC 00452
WAUZZZ8LX3A082475 AUZ7Z0C2318592
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 06435
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
35-00 - -
Address 56 -------------------------------------------------------
Controller: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00001
Shop #: WSC 00415
1 Fault Found:
00879 - Connection to Speaker Front Right
End -------------------------------------------------------
777
708
449
