Help needed for two fault codes please.
dt-tdi
Active Member
Hi all
Has anyone had this same issue please?
I noticed the engine management light come on this morning on my 2014 A6 3.0bitdi on the way to work and a considerable loss of top end power with the engine unwilling to rev freely at the top end of the rev range.
Scanned with VCDS and the two following fault codes came up:
The second fault code (12291 - Energy Management Active) cleared putting out the engine management light out but the Intake manifold flap fault code remained with the same loss top of top end power on a following road test.
If anyone has any ideas or has experienced the same issue I would be grateful for some advice to fix as soon as possible.
Thanks in advance.
1 Fault Found:
9129 - Intake Manifold Flap; Bank 1
P2006 00 [175] - Stuck Closed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 105172 km
Date: 2022.02.27
Time: 12:47:58
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 87 °C
Intake air temperature: 16 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.900 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Intake manifold Runner Control (IMRC): activation: 100.00 %
Intake manifold Runner Control (IMRC): acknowledgment: 14.54 %
Intake manifold runner control (IMRC): offset closed: 0.00 %
Actuator for intake manifold runner control: status-Bits 0-7: 0
Actuator for intake manifold runner control: status-Bits 0-7: 8
Actuator for intake manifold runner control: status-Bits 0-7: 55
Actuator for intake manifold runner control: status-Bits 0-7: 7
Intake manif runner actuator: uncond volt actual value: 1289.2 mV
Readiness: 1 1 0 0 0
1 Fault Found:
U140B 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 40
Mileage: 105041 km
Date: 2022.02.23
Time: 11:21:02
Voltage terminal 30: 11.6 V
Voltage terminal 15: 0.0 V
Control Module temperature: 9 °C
System status: Awake_Timer_active
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 3
